Up to 20% off select tools
Asus P45V: Replacing the RAM
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
73
All Time:
278
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 45 seconds - 5 minutes
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
The Asus P45V Series all use sodimm DDR3 and sodimm DDR3L. Any other formats WON'T WORK!
What you need:
  • Regular screwdriver
  • Pair of hands
  • Your new RAM
    1. Asus P45V: Replacing the RAM, 1. Removing the small cover: step 1, image 1 of 1
      • Unscrew the 2 screws which are marked above.
      • Remove the SD Card from the SD Card Slot
      • Push the cover down and pull towards you
      Ask FixBot
    2. Asus P45V: Replacing the RAM, 2. Remove the Ram: step 2, image 1 of 3 Asus P45V: Replacing the RAM, 2. Remove the Ram: step 2, image 2 of 3 Asus P45V: Replacing the RAM, 2. Remove the Ram: step 2, image 3 of 3
      • The RAM is found in the compartment to the right
      • To remove any of the 2 RAM modules from their slots:
      • 1. Pull the left RAM hinge to the right
      • 2. Pull the right RAM hinge to the left
      • 3. The RAM should pop upwards
      • 4. Carefully take out the RAM
      Ask FixBot
      • The last step is inserting the RAM:
      • 1. Carefully insert the new RAM the same way the old RAM popped upwards in Step 2
      • 2. Push the new RAM downwards the same way it was in Step 1, until you hear a sudden click. That was the hinges securing your new RAM into place.
      • Don't forget to put on the plastic cover you have pulled off in step 1.
      • Now you have successfully replaced the RAM for your Asus P45V Laptop!
      Ask FixBot
Arbeite die Schritte in umgekehrter Reihenfolge ab, um dein Gerät wieder zusammenzubauen.
Author
with
GamePlayer102
97 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 73
All Time: 278
