Asus N56VM Motherboard Replacement
    1. Asus N56VM Motherboard Replacement, Remove battery: step 1, image 1 of 1
      • Remove the battery and the AC power
      Ask FixBot
    2. Asus N56VM Motherboard Replacement, Remove bottom cover: step 2, image 1 of 2 Asus N56VM Motherboard Replacement, Remove bottom cover: step 2, image 2 of 2
      • Remove the M2x4 screw of the bottom cover
      • Remove the bottom cover by sliding it downwards
      Ask FixBot
    1. Asus N56VM Motherboard Replacement, Optical drive: step 3, image 1 of 1
      • Remove the screw holding the optical drive
      Ask FixBot
    2. Asus N56VM Motherboard Replacement: step 4, image 1 of 1
      • Pull out the optical drive
      Ask FixBot
    1. Asus N56VM Motherboard Replacement, Hard Disk: step 5, image 1 of 2 Asus N56VM Motherboard Replacement, Hard Disk: step 5, image 2 of 2
      • Remove the screws
      • Remove the 3 M2x10 screws
      • Remove the one M2x4 screw
      Ask FixBot
    2. Asus N56VM Motherboard Replacement: step 6, image 1 of 1
      • Gently pull the hard disk to the left
      Ask FixBot
    1. Asus N56VM Motherboard Replacement, RAM: step 7, image 1 of 1
      • Remove the two RAM modules
      • Pop them out gently
      • Make sure you are electrostatically not loaded
      Ask FixBot
    2. Asus N56VM Motherboard Replacement: step 8, image 1 of 1
      • Detach the two cables from the wireless module
      Ask FixBot
    3. Asus N56VM Motherboard Replacement: step 9, image 1 of 2 Asus N56VM Motherboard Replacement: step 9, image 2 of 2
      • Remove all screws from the bottom cover
      • Remove 7 M2x10 screws
      • Remove 3 M2x4 screws
      • Remove 2 small screws
      Ask FixBot
    4. Asus N56VM Motherboard Replacement: step 10, image 1 of 3 Asus N56VM Motherboard Replacement: step 10, image 2 of 3 Asus N56VM Motherboard Replacement: step 10, image 3 of 3
      • Open the lid of the notebook
      • Use a plastic opening tool to pry the bottom case
      • Be very careful when opening so that the cables in the case are not severed.
      Ask FixBot
    5. Asus N56VM Motherboard Replacement: step 11, image 1 of 1
      • The motherboard is still connected to the bottom case by several cables, so don't try to remove it entirely just yet.
      • Hold the upper part with one hand, and use your other hand to disconnect the black&white cable (antenna for the wifi card)
      Ask FixBot
    6. Asus N56VM Motherboard Replacement: step 12, image 1 of 1
      • Continue to hold the upper part with one hand, and use your other hand to disconnect the black ribbon cable
      • Remove the upper part with the motherboard
      Ask FixBot
    7. Asus N56VM Motherboard Replacement: step 13, image 1 of 2 Asus N56VM Motherboard Replacement: step 13, image 2 of 2
      • This component is attached by a cable to the lower side of the motherboard therefore it is advised to remove it.
      • Remove the two screws holding the VGA IC
      • Lift the IC
      Ask FixBot
    8. Asus N56VM Motherboard Replacement: step 14, image 1 of 3 Asus N56VM Motherboard Replacement: step 14, image 2 of 3 Asus N56VM Motherboard Replacement: step 14, image 3 of 3
      • Remove the cable by first lifting the black holder and then removing the cable
      Ask FixBot
    9. Asus N56VM Motherboard Replacement: step 15, image 1 of 1
      • Remove the white cable simply by pulling it out from the connector
      Ask FixBot
    10. Asus N56VM Motherboard Replacement: step 16, image 1 of 3 Asus N56VM Motherboard Replacement: step 16, image 2 of 3 Asus N56VM Motherboard Replacement: step 16, image 3 of 3
      • Remove the touchpad cable by first lifting the black holder
      Ask FixBot
    11. Asus N56VM Motherboard Replacement: step 17, image 1 of 3 Asus N56VM Motherboard Replacement: step 17, image 2 of 3 Asus N56VM Motherboard Replacement: step 17, image 3 of 3
      • Remove the two keyboard cables by first pulling out the black holders. After that the cables are released
      Ask FixBot
    12. Asus N56VM Motherboard Replacement: step 18, image 1 of 2 Asus N56VM Motherboard Replacement: step 18, image 2 of 2
      • Remove the four screws holding the motherboard
      • Remove the screw holding the fan
      • Pry out the plastic thing holding the motherboard in place
      Ask FixBot
2 other people completed this guide.
Stanky
1,385 Reputation
6 Guides authored
2 Guide Comments
Can you please help me locate the gpu VRM on the motherboard? My gpu is faulty and needs to be rebonded, so I wanna permanently disable it.
Coll Student - Reply Share
Sorry, I can’t help you with that
Stanky - Reply Share
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 139
All Time: 4,286
