Introduction
This guide is to show you how to replace the battery in an Asus MeMO Pad HD 7. This is a simple procedure that can be accomplished by anyone.
Carefully remove the back panel by using a plastic opening tool to remove the panel off the device.
Pull the back panel away from the device.
Using a spudger carefully pry the battery up. It is glued down so slight pressure may be needed.
15 other people completed this guide.
4 Guide Comments
How did you fix the sd card port?
where can i buy battery for asus memopad here in naga city, cam sur,philippines?
