Asus MeMO Pad 7 ME170C Battery Replacement
    1. Asus MeMO Pad 7 ME170C  Battery Replacement, Battery: step 1, image 1 of 3 Asus MeMO Pad 7 ME170C  Battery Replacement, Battery: step 1, image 2 of 3 Asus MeMO Pad 7 ME170C  Battery Replacement, Battery: step 1, image 3 of 3
      • Before beginning to disassemble, Power off the device.
      • Excessive force can result in damaged or cracked screen. Be Gentle.
      • Gently wedge a Jimmy into the seam of the device.
      • Gently pry the Jimmy all around the seam until the back panel is detached.
      Ask FixBot
    2. Asus MeMO Pad 7 ME170C  Battery Replacement: step 2, image 1 of 3 Asus MeMO Pad 7 ME170C  Battery Replacement: step 2, image 2 of 3 Asus MeMO Pad 7 ME170C  Battery Replacement: step 2, image 3 of 3
      • Locate the black bundle cable connector attached to the battery of the phone.
      • Do not push down. Slide in a forward motion to avoid breaking any inner pieces.
      • Using a plastic opening tool, gently slide the black bundle cable connector towards the battery in a back and forth motion until loosened and it slides out of connection port.
      Ask FixBot
    3. Asus MeMO Pad 7 ME170C  Battery Replacement: step 3, image 1 of 3 Asus MeMO Pad 7 ME170C  Battery Replacement: step 3, image 2 of 3 Asus MeMO Pad 7 ME170C  Battery Replacement: step 3, image 3 of 3
      • Using a plastic opening tool, pry out the batteries to loosen them out.
      • The battery will be pried out of its port.
      • Lift the battery out of its port
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 60
All Time: 3,610
