Asus M51E-B2 Swivel Camera Replacement
    1. Asus M51E-B2  Swivel Camera Replacement, Swivel Camera: step 1, image 1 of 1
      • Open the laptop.
      • Press and hold the power button until the laptop powers off.
      Ask FixBot
    2. Asus M51E-B2  Swivel Camera Replacement: step 2, image 1 of 2 Asus M51E-B2  Swivel Camera Replacement: step 2, image 2 of 2
      • Use a metal spudger prying tool to remove the outer screen cover of the laptop.
      • Gently work your way clockwise around the outer part of the screen.
      Ask FixBot
    3. Asus M51E-B2  Swivel Camera Replacement: step 3, image 1 of 2 Asus M51E-B2  Swivel Camera Replacement: step 3, image 2 of 2
      • Use the Phillips PH0 head screwdriver to remove the two 2.5 mm screws located on the left side of the camera.
      • Use the Phillips PH0 head screwdriver to remove the one 2.5 millimeter screw that goes through the left side of the camera.
      Ask FixBot
    4. Asus M51E-B2  Swivel Camera Replacement: step 4, image 1 of 1
      • Find the wiring harness on the right side of the camera.
      • Using your fingers, gently remove the wiring harness connected to the right side of the camera.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 71
All Time: 820
