Asus M32BF-US002T RAM Replacement
    1. Asus M32BF-US002T RAM Replacement, RAM: step 1, image 1 of 2 Asus M32BF-US002T RAM Replacement, RAM: step 1, image 2 of 2
      • The side panel is located on the left side of the computer.
      • The 2nd image shows the correct side we will be working on.
      Ask FixBot
    2. Asus M32BF-US002T RAM Replacement: step 2, image 1 of 3 Asus M32BF-US002T RAM Replacement: step 2, image 2 of 3 Asus M32BF-US002T RAM Replacement: step 2, image 3 of 3
      • Face the back of the desktop towards you on a flat work service.
      • Use the Phillips #00 to remove the two 3.5 mm screws on the edge of the side panel.
      Ask FixBot
    3. Asus M32BF-US002T RAM Replacement: step 3, image 1 of 2 Asus M32BF-US002T RAM Replacement: step 3, image 2 of 2
      • Pull the small tab on the left side panel.
      • Continue to pull gently until you hear a click sound, then remove the side panel.
      Ask FixBot
    4. Asus M32BF-US002T RAM Replacement: step 4, image 1 of 3 Asus M32BF-US002T RAM Replacement: step 4, image 2 of 3 Asus M32BF-US002T RAM Replacement: step 4, image 3 of 3
      • Locate the RAM modules.
      • They are thin, long, green, and rectangle shaped.
      Ask FixBot
    5. Asus M32BF-US002T RAM Replacement: step 5, image 1 of 3 Asus M32BF-US002T RAM Replacement: step 5, image 2 of 3 Asus M32BF-US002T RAM Replacement: step 5, image 3 of 3
      • Unlock the locks that are holding the RAM module down, by pushing them downwards.
      • Although not shown in the first picture, there is also a lock at the bottom and can be seen on picture 3.
      Ask FixBot
    6. Asus M32BF-US002T RAM Replacement: step 6, image 1 of 2 Asus M32BF-US002T RAM Replacement: step 6, image 2 of 2
      • Pull the RAM straight out.
      • Wiggling the RAM out of its slot may cause damage to the RAM module, or the RAM slot itself. Pull straight out!
      Ask FixBot
    7. Asus M32BF-US002T RAM Replacement: step 7, image 1 of 1
      • Before installing the new RAM, ensure the slots have been unlocked as seen in this picture.
      • You can tell it is unlocked when the lock looks like it has been pushed away from the slot.
      • If you are adding an additional RAM module, ensure the 2nd RAM slot is unlocked as well.
      Ask FixBot
    8. Asus M32BF-US002T RAM Replacement: step 8, image 1 of 2 Asus M32BF-US002T RAM Replacement: step 8, image 2 of 2
      • Before installing, ensure the gap on the RAM module aligns with the notch on the RAM slot.
      Ask FixBot
    9. Asus M32BF-US002T RAM Replacement: step 9, image 1 of 1
      • Align the gap on the RAM module with the notch on the RAM slot.
      • Push straight down until you hear a click or until the locks have locked on their own.
      • An uncomfortable amount of force may be needed in order to successfully install the RAM.
      Ask FixBot
    10. Asus M32BF-US002T RAM Replacement: step 10, image 1 of 3 Asus M32BF-US002T RAM Replacement: step 10, image 2 of 3 Asus M32BF-US002T RAM Replacement: step 10, image 3 of 3
      • Grab the side panel, and place it on the side of the computer.
      • Slide the side panel to the right to lock the side panel.
      Ask FixBot
    11. Asus M32BF-US002T RAM Replacement: step 11, image 1 of 2 Asus M32BF-US002T RAM Replacement: step 11, image 2 of 2
      • Using your Phillips #00 screwdriver, take the screws from Step 2 and screw them back onto the side panel.
      • You have successfully installed RAM into your desktop computer! You are now finished.
      Ask FixBot
3 other people completed this guide.
Shaun Pangilinan
274 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 21
Past 30 Days: 66
All Time: 2,326
