Asus L410MA-Ts02 Battery Replacement
View statistics:
Past 24 Hours:
5
Past 7 Days:
19
Past 30 Days:
87
All Time:
836
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will walk you through how to replace the battery in the Asus L410MA-TS02 laptop.
There is minimal risk to removing the battery, but it is important to wear an ESD wrist strap when opening any electronic device. No special skills are required, so this is a very simple process to follow. The only risk is possible damage to the laptop if instructions are not followed correctly.
Battery replacement can be necessary when the battery is damaged, ineffective, or degraded due to age. Asus laptops in particular have many cases of batteries draining too quickly or turning off soon after being unplugged from a charger. If any of these apply, then replacing the battery may fix the issue.
Tools
    1. Asus L410MA-Ts02 Battery Replacement, Back Cover: step 1, image 1 of 2 Asus L410MA-Ts02 Battery Replacement, Back Cover: step 1, image 2 of 2
      • Remove ten 6 mm screws that secure the lower case using a Phillips #1 screwdriver.
      • Carefully remove the lower case.
      Ask FixBot
    1. Asus L410MA-Ts02 Battery Replacement, Battery: step 2, image 1 of 1
      • Remove the 4 mm screws that are securing the battery using a Phillips #1 screwdriver.
      Ask FixBot
    2. Asus L410MA-Ts02 Battery Replacement: step 3, image 1 of 1
      • Grip the white battery connecter found on its side and pull it directly out of its battery port.
      • Do not pull at an angle or roughly tug it out.
      Ask FixBot
    3. Asus L410MA-Ts02 Battery Replacement: step 4, image 1 of 1
      • Carefully lift the battery and remove it from the laptop.
      Ask FixBot
john
611 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 19
Past 30 Days: 87
All Time: 836
