Asus L410MA-MH09-CA Keyboard Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
10
Past 30 Days:
70
All Time:
660
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 25 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Introduction
Go to step 1 ↓
If you're experiencing issues with your ASUS L410MA-MH09-CA keyboard not responding or being physically damaged, you may need to replace your keyboard, use this guide to learn how to replace your keyboard.
When replacing your keyboard be sure to check if the keyboard replacement you're buying has the same connectors. Here is a link for a suitable keyboard replacement. https://a.co/d/1l29C2m
Tools
    1. Asus L410MA-MH09-CA Keyboard Replacement, Battery: step 1, image 1 of 1
      • Remove all ten 6 mm Phillips #1 screws that secure the lower case.
      • Insert an opening pick in the gap between the lower case and chassis.
      • Slide the opening pick around the entire perimeter of the laptop until the lower case fully releases.
      • Remove the lower case.
      Ask FixBot
    2. Asus L410MA-MH09-CA Keyboard Replacement: step 2, image 1 of 1
      • Remove the 4 mm Phillips #1 screws that secure the battery.
      Ask FixBot
    3. Asus L410MA-MH09-CA Keyboard Replacement: step 3, image 1 of 1
      • Grip the white battery connector and pull it directly out of its battery port.
      Ask FixBot
    4. Asus L410MA-MH09-CA Keyboard Replacement: step 4, image 1 of 1
      • Lift the battery out carefully.
      Ask FixBot
    1. Asus L410MA-MH09-CA Keyboard Replacement, Keyboard: step 5, image 1 of 1
      • Use a Phillips #1 screwdriver to remove the screws that secure the hinges.
      • Lift the hinges up and out.
      Ask FixBot
    2. Asus L410MA-MH09-CA Keyboard Replacement: step 6, image 1 of 2 Asus L410MA-MH09-CA Keyboard Replacement: step 6, image 2 of 2
      • Disconnect the battery and display connectors.
      Ask FixBot
    3. Asus L410MA-MH09-CA Keyboard Replacement: step 7, image 1 of 3 Asus L410MA-MH09-CA Keyboard Replacement: step 7, image 2 of 3 Asus L410MA-MH09-CA Keyboard Replacement: step 7, image 3 of 3
      • Remove the four 4 mm Phillips #1 screws that secure the heatsink.
      • Remove the heatsink.
      • Remove the remaining two 4 mm Phillips #1 screws that secure the motherboard.
      • Remove the motherboard.
      Ask FixBot
    4. Asus L410MA-MH09-CA Keyboard Replacement: step 8, image 1 of 1
      • Use a spudger to pry around the entire perimeter of the metal bracket until it fully releases.
      • Remove the metal bracket.
      Ask FixBot
    5. Asus L410MA-MH09-CA Keyboard Replacement: step 9, image 1 of 2 Asus L410MA-MH09-CA Keyboard Replacement: step 9, image 2 of 2
      • Carefully disconnect the wide blue ribbon cable.
      • Remove the keyboard.
      Ask FixBot
Take your e-waste to an R2 or e-Stewards certified recycler.m
Jimmy
361 Reputation
3 Guides authored
Gateway, Team 8-2, Gonzalez Fall 2024 Member of Gateway, Team 8-2, Gonzalez Fall 2024
GCC-GONZALEZ-F24S8G2
5 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 70
All Time: 660
