Asus L406M Motherboard Replacement
    1. Asus L406M Motherboard Replacement, Lower Case: step 1, image 1 of 3 Asus L406M Motherboard Replacement, Lower Case: step 1, image 2 of 3 Asus L406M Motherboard Replacement, Lower Case: step 1, image 3 of 3
      • Use an opening tool to remove each of the two rubber feet near the laptop hinges.
      • The rubber feet are connected using adhesive, so you'll have to use a little bit of force to get them off. If you intend to reuse the feet, take care not to warp or tear them.
      Ask FixBot
    2. Asus L406M Motherboard Replacement: step 2, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the two 6.4 mm-long silver screws.
      Ask FixBot
    3. Asus L406M Motherboard Replacement: step 3, image 1 of 2 Asus L406M Motherboard Replacement: step 3, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the remaining eleven 6.4 mm-long black screws securing the lower case.
      Ask FixBot
    4. Asus L406M Motherboard Replacement: step 4, image 1 of 2 Asus L406M Motherboard Replacement: step 4, image 2 of 2
      • Insert an opening pick or opening tool into the seam between the lower case and chassis.
      • Pry around the entire perimeter until the lower case is fully released.
      • Remove the lower case.
      Ask FixBot
    1. Asus L406M Motherboard Replacement, Battery: step 5, image 1 of 3 Asus L406M Motherboard Replacement, Battery: step 5, image 2 of 3 Asus L406M Motherboard Replacement, Battery: step 5, image 3 of 3
      • Remove the two 3.2 mm-long Phillips #0 screws that secure the battery.
      • Disconnect the battery connector cable and the speaker cable from their motherboard sockets.
      Ask FixBot
    2. Asus L406M Motherboard Replacement: step 6, image 1 of 2 Asus L406M Motherboard Replacement: step 6, image 2 of 2
      • Carefully unseat and remove the battery.
      • Take care not to bend, warp, twist, or puncture the battery.
      Ask FixBot
    1. Asus L406M Motherboard Replacement, Motherboard: step 7, image 1 of 3 Asus L406M Motherboard Replacement, Motherboard: step 7, image 2 of 3 Asus L406M Motherboard Replacement, Motherboard: step 7, image 3 of 3
      • Use a Phillips #0 screwdriver to remove five 3.2 mm-long screws that secure the motherboard.
      • Using the same Phillips #0 screwdriver, remove the 2.4 mm-long screw that secures the Wi-Fi card.
      Ask FixBot
    2. Asus L406M Motherboard Replacement: step 8, image 1 of 3 Asus L406M Motherboard Replacement: step 8, image 2 of 3 Asus L406M Motherboard Replacement: step 8, image 3 of 3
      • Use tweezers to flip up the small black locking flaps that secure the motherboard ribbon cables in place, and gently disconnect the ribbon cables.
      • Be careful when doing this! Ribbon cables can break if you tug them too hard!
      Ask FixBot
    3. Asus L406M Motherboard Replacement: step 9, image 1 of 1
      • Carefully lift the tape securing the display connector and disconnect it.
      Ask FixBot
    4. Asus L406M Motherboard Replacement: step 10, image 1 of 3 Asus L406M Motherboard Replacement: step 10, image 2 of 3 Asus L406M Motherboard Replacement: step 10, image 3 of 3
      • Disconnect the Wi-Fi card from its motherboard socket.
      • Carefully lift and remove the motherboard.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 68
All Time: 186
