Asus L406M Lower Case Replacement
    1. Asus L406M Lower Case Replacement, Lower Case: step 1, image 1 of 3 Asus L406M Lower Case Replacement, Lower Case: step 1, image 2 of 3 Asus L406M Lower Case Replacement, Lower Case: step 1, image 3 of 3
      • Use an opening tool to remove each of the two rubber feet near the laptop hinges.
      • The rubber feet are connected using adhesive, so you'll have to use a little bit of force to get them off. If you intend to reuse the feet, take care not to warp or tear them.
      Ask FixBot
    2. Asus L406M Lower Case Replacement: step 2, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the two 6.4 mm-long silver screws.
      Ask FixBot
    3. Asus L406M Lower Case Replacement: step 3, image 1 of 2 Asus L406M Lower Case Replacement: step 3, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the remaining eleven 6.4 mm-long black screws securing the lower case.
      Ask FixBot
    4. Asus L406M Lower Case Replacement: step 4, image 1 of 2 Asus L406M Lower Case Replacement: step 4, image 2 of 2
      • Insert an opening pick or opening tool into the seam between the lower case and chassis.
      • Pry around the entire perimeter until the lower case is fully released.
      • Remove the lower case.
      Ask FixBot
Connor Bassolino
26,156 Reputation
125 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 59
All Time: 134
