Asus L406M Battery Replacement
    1. Asus L406M Battery Replacement, Lower Case: step 1, image 1 of 3 Asus L406M Battery Replacement, Lower Case: step 1, image 2 of 3 Asus L406M Battery Replacement, Lower Case: step 1, image 3 of 3
      • Use an opening tool to remove each of the two rubber feet near the laptop hinges.
      • The rubber feet are connected using adhesive, so you'll have to use a little bit of force to get them off. If you intend to reuse the feet, take care not to warp or tear them.
      Ask FixBot
    2. Asus L406M Battery Replacement: step 2, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the two 6.4 mm-long silver screws.
      Ask FixBot
    3. Asus L406M Battery Replacement: step 3, image 1 of 2 Asus L406M Battery Replacement: step 3, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the remaining eleven 6.4 mm-long black screws securing the lower case.
      Ask FixBot
    4. Asus L406M Battery Replacement: step 4, image 1 of 2 Asus L406M Battery Replacement: step 4, image 2 of 2
      • Insert an opening pick or opening tool into the seam between the lower case and chassis.
      • Pry around the entire perimeter until the lower case is fully released.
      • Remove the lower case.
      Ask FixBot
    1. Asus L406M Battery Replacement, Battery: step 5, image 1 of 3 Asus L406M Battery Replacement, Battery: step 5, image 2 of 3 Asus L406M Battery Replacement, Battery: step 5, image 3 of 3
      • Remove the two 3.2 mm-long Phillips #0 screws that secure the battery.
      • Disconnect the battery connector cable and the speaker cable from their motherboard sockets.
      Ask FixBot
    2. Asus L406M Battery Replacement: step 6, image 1 of 2 Asus L406M Battery Replacement: step 6, image 2 of 2
      • Carefully unseat and remove the battery.
      • Take care not to bend, warp, twist, or puncture the battery.
      Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 62
All Time: 220
