Asus K55a-si50301p RAM Replacement
    1. Asus K55a-si50301p RAM Replacement, Battery: step 1, image 1 of 1
      • Press and slide the two battery retention clips on either side of the battery towards the unlock position.
      Ask FixBot
    2. Asus K55a-si50301p RAM Replacement: step 2, image 1 of 1
      • Pull the right side retention clip so that the red indicator is showing.
      • The small graphic below the retention clip denotes locked and unlocked positions. The clip will stay put once moved into position.
      Ask FixBot
    3. Asus K55a-si50301p RAM Replacement: step 3, image 1 of 1
      • Pull the retention clip on the left hand side of the laptop away from the battery.
      • Gently pull the battery out with your free hand.
      Ask FixBot
    1. Asus K55a-si50301p RAM Replacement, Lower Back Panel: step 4, image 1 of 1
      • Remove the two 8.5mm screws using a PH0 screwdriver.
      Ask FixBot
    2. Asus K55a-si50301p RAM Replacement: step 5, image 1 of 1
      • Using the iFixit opening tool, gently pry the plastic cover away from its original position.
      Ask FixBot
    3. Asus K55a-si50301p RAM Replacement: step 6, image 1 of 1
      • Gently pull up and then towards you until the plastic cover is free.
      Ask FixBot
    1. Asus K55a-si50301p RAM Replacement, RAM: step 7, image 1 of 1
      • Press slot pins outwards with gentle force.
      Ask FixBot
    2. Asus K55a-si50301p RAM Replacement: step 8, image 1 of 1
      • After the RAM stick pops up, pull it towards you to gently remove it.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 79
All Time: 904
