Asus K55VD Fan Replacement
      • Power off the device completely
      • Flip the device over to its back cover.
      • Use the switches to release the battery from its adapter.
      Ask FixBot
    1. Asus K55VD Fan Replacement, Hard Drive: step 2, image 1 of 2 Asus K55VD Fan Replacement, Hard Drive: step 2, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the two 1.5 mm screws in the smaller portion of the bottom cover.
      • After removing the screws, remove the smaller cover.
      Ask FixBot
    2. Asus K55VD Fan Replacement: step 3, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the 1.5 mm screws that hold down the hard drive.
      Ask FixBot
    3. Asus K55VD Fan Replacement: step 4, image 1 of 2 Asus K55VD Fan Replacement: step 4, image 2 of 2
      • Remove the hard drive from the slot.
      • Remove the hard drive from its shell.
      Ask FixBot
    1. Asus K55VD Fan Replacement, Fan: step 5, image 1 of 3 Asus K55VD Fan Replacement, Fan: step 5, image 2 of 3 Asus K55VD Fan Replacement, Fan: step 5, image 3 of 3
      • Remove all 12 screws from the bottom cover with a Phillips #0 screwdriver.
      • The four screws nearest the display hinges are longer.
      • The single screw in the middle of the bottom cover is shorter than the rest.
      Ask FixBot
    2. Asus K55VD Fan Replacement: step 6, image 1 of 3 Asus K55VD Fan Replacement: step 6, image 2 of 3 Asus K55VD Fan Replacement: step 6, image 3 of 3
      • After the screws are removed, Orientate the device so that the keyboard is shown.
      • Using the Plastic Pry tool separate the keyboard panel from the rest of the laptop.
      Ask FixBot
    3. Asus K55VD Fan Replacement: step 7, image 1 of 2 Asus K55VD Fan Replacement: step 7, image 2 of 2
      • Before the keyboard panel can be fully removed, detach the three cords that connect to the keyboard.
      • Lift up on the black tab and the cord will fall out.
      Ask FixBot
    4. Asus K55VD Fan Replacement: step 8, image 1 of 3 Asus K55VD Fan Replacement: step 8, image 2 of 3 Asus K55VD Fan Replacement: step 8, image 3 of 3
      • Remove the optical dive by sliding it outward.
      Ask FixBot
    5. Asus K55VD Fan Replacement: step 9, image 1 of 3 Asus K55VD Fan Replacement: step 9, image 2 of 3 Asus K55VD Fan Replacement: step 9, image 3 of 3
      • Now remove the two wires shown by pulling away from the motherboard.
      Ask FixBot
    6. Asus K55VD Fan Replacement: step 10, image 1 of 3 Asus K55VD Fan Replacement: step 10, image 2 of 3 Asus K55VD Fan Replacement: step 10, image 3 of 3
      • Remove the three screws holding the motherboard and fan in place using the Phillips #0 bit.
      • The top left screw shown in the first picture is easily broken
      Ask FixBot
    7. Asus K55VD Fan Replacement: step 11, image 1 of 3 Asus K55VD Fan Replacement: step 11, image 2 of 3 Asus K55VD Fan Replacement: step 11, image 3 of 3
      • lift up on the entire motherboard and unplug the bottom wires connected to the fan.
      Ask FixBot
    8. Asus K55VD Fan Replacement: step 12, image 1 of 2 Asus K55VD Fan Replacement: step 12, image 2 of 2
      • After all cords have been removed, the fan can be removed as well.
      Ask FixBot
8 other people completed this guide.
2 Guide Comments
At step 5, you should also unscrew the bottom silver screw and unplug the wifi antennas.
https://i.imgur.com/vRrlRkv.png
Daniel - Reply Share
At step 3, the bottom left screw does not hold down the drive bay. Unsrew that screw in step 5.
Past 24 Hours: 5
Past 7 Days: 28
Past 30 Days: 98
All Time: 3,907
