Asus K55VD DVD Player Replacement
      • Power off the device completely
      • Flip the device over to its back cover.
      • Use the switches to release the battery from its adapter.
      Ask FixBot
    1. Asus K55VD DVD Player Replacement, Hard Drive: step 2, image 1 of 2 Asus K55VD DVD Player Replacement, Hard Drive: step 2, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the two 1.5 mm screws in the smaller portion of the bottom cover.
      • After removing the screws, remove the smaller cover.
      Ask FixBot
    2. Asus K55VD DVD Player Replacement: step 3, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the 1.5 mm screws that hold down the hard drive.
      Ask FixBot
    3. Asus K55VD DVD Player Replacement: step 4, image 1 of 2 Asus K55VD DVD Player Replacement: step 4, image 2 of 2
      • Remove the hard drive from the slot.
      • Remove the hard drive from its shell.
      Ask FixBot
    1. Asus K55VD DVD Player Replacement, Optical Disk Drive: step 5, image 1 of 1
      • Using the the Philips #0 Screwdriver remove highlighted screws.
      Ask FixBot
    2. Asus K55VD DVD Player Replacement: step 6, image 1 of 1
      Tool used on this step:
      Buy
      • Lift plastic cover with tweezers.
      • Remove screw.
      Ask FixBot
    3. Asus K55VD DVD Player Replacement: step 7, image 1 of 1
      • Lift keyboard panel with plastic pry tool to remove.
      Ask FixBot
    4. Asus K55VD DVD Player Replacement: step 8, image 1 of 2 Asus K55VD DVD Player Replacement: step 8, image 2 of 2
      • Unhook all ribbons to remove keyboard panel completely.
      Ask FixBot
    5. Asus K55VD DVD Player Replacement: step 9, image 1 of 2 Asus K55VD DVD Player Replacement: step 9, image 2 of 2
      • Slide the DVD Player outward.
      Ask FixBot
1 Guide Comment
LOL if you want to get out drive, open dvd drive, turn laptop off, remove screw cover, unscrew, pull the drive out, done :D This is stupidly overcomplicated and unnecessary.
Luke Malatinsky - Reply Share
Past 24 Hours: 5
Past 7 Days: 28
Past 30 Days: 91
All Time: 1,765
