Asus K55N-DS81 Rear Panel Replacement
    1. Asus K55N-DS81 Rear Panel Replacement, Battery: step 1, image 1 of 1
      • Flip the laptop over, such that the bottom of the laptop is facing upwards.
      • Ensure that the laptop is powered off prior to following this guide.
      Ask FixBot
    2. Asus K55N-DS81 Rear Panel Replacement: step 2, image 1 of 2 Asus K55N-DS81 Rear Panel Replacement: step 2, image 2 of 2
      • Pull the latch to the right of the battery to the right.
      Ask FixBot
    3. Asus K55N-DS81 Rear Panel Replacement: step 3, image 1 of 2 Asus K55N-DS81 Rear Panel Replacement: step 3, image 2 of 2
      • Pull the latch to the left of the battery to the left. Hold the latch open with a finger to prevent it from closing.
      Ask FixBot
    4. Asus K55N-DS81 Rear Panel Replacement: step 4, image 1 of 2 Asus K55N-DS81 Rear Panel Replacement: step 4, image 2 of 2
      • While holding the second latch from the previous step, use another hand to reach underneath the battery.
      • Pull the battery upwards and away from the laptop to remove it.
      Ask FixBot
    1. Asus K55N-DS81 Rear Panel Replacement, Rear Panel: step 5, image 1 of 2 Asus K55N-DS81 Rear Panel Replacement, Rear Panel: step 5, image 2 of 2
      • Using a JIS #00 screwdriver, unscrew the two 5 mm screws on either side of the laptop panel.
      Ask FixBot
    2. Asus K55N-DS81 Rear Panel Replacement: step 6, image 1 of 3 Asus K55N-DS81 Rear Panel Replacement: step 6, image 2 of 3 Asus K55N-DS81 Rear Panel Replacement: step 6, image 3 of 3
      • Remove the panel by pushing away from the laptop until the panel is free of the laptop.
      • Lift to remove the panel.
      Ask FixBot
Elliott Beckner
543 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 28
All Time: 712
