Asus K53E-BBR3 RAM Replacement
    1. Asus K53E-BBR3 RAM Replacement, Battery: step 1, image 1 of 3 Asus K53E-BBR3 RAM Replacement, Battery: step 1, image 2 of 3 Asus K53E-BBR3 RAM Replacement, Battery: step 1, image 3 of 3
      • Place your laptop face down in front of you.
      • Slide the button in the top right corner to the right so that the orange marker is showing.
      • Press the spring loaded latch to release the battery from the computer.
      Ask FixBot
    1. Asus K53E-BBR3 RAM Replacement, Back Panel: step 2, image 1 of 1
      • Unscrew two 5mm Phillips #1 screws.
      Ask FixBot
    2. Asus K53E-BBR3 RAM Replacement: step 3, image 1 of 1
      • Pull down and lift up on the back panel to remove it.
      Ask FixBot
    1. Asus K53E-BBR3 RAM Replacement, RAM: step 4, image 1 of 1
      • After sliding down the back panel you will see three individual compartments with different components. The one to the far right is the RAM.
      Ask FixBot
    2. Asus K53E-BBR3 RAM Replacement: step 5, image 1 of 3 Asus K53E-BBR3 RAM Replacement: step 5, image 2 of 3 Asus K53E-BBR3 RAM Replacement: step 5, image 3 of 3
      • To remove the RAM stick, locate the silver tabs holding the stick in place.
      • Move the silver tabs so that the detents are no longer holding the RAM in place. Once you've done this, the RAM will pop up and out.
      Ask FixBot
Bradley Anastacio
213 Reputation
1 Guide authored
UMass Dartmouth, Team 1-1, Catania Fall 2016 Member of UMass Dartmouth, Team 1-1, Catania Fall 2016
UMASSD-CATANIA-F16S1G1
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 26
Past 30 Days: 110
All Time: 1,273
