Asus K53E-BBR3 Optical Drive Replacement
    1. Asus K53E-BBR3 Optical Drive Replacement, Battery: step 1, image 1 of 3 Asus K53E-BBR3 Optical Drive Replacement, Battery: step 1, image 2 of 3 Asus K53E-BBR3 Optical Drive Replacement, Battery: step 1, image 3 of 3
      • Place your laptop face down in front of you.
      • Slide the button in the top right corner to the right so that the orange marker is showing.
      • Press the spring loaded latch to release the battery from the computer.
      Ask FixBot
    1. Asus K53E-BBR3 Optical Drive Replacement, Back Panel: step 2, image 1 of 1
      • Unscrew two 5mm Phillips #1 screws.
      Ask FixBot
    2. Asus K53E-BBR3 Optical Drive Replacement: step 3, image 1 of 1
      • Pull down and lift up on the back panel to remove it.
      Ask FixBot
    1. Asus K53E-BBR3 Optical Drive Replacement, Keyboard: step 4, image 1 of 3 Asus K53E-BBR3 Optical Drive Replacement, Keyboard: step 4, image 2 of 3 Asus K53E-BBR3 Optical Drive Replacement, Keyboard: step 4, image 3 of 3
      • There is a ribbon connector underneath the keyboard. When lifting up the keyboard be gentle and carefully it up.
      • Insert the spudger into the indent near the "ESC" key.
      • Firmly wiggle the spudger across the keyboard in between the space until you can remove the keyboard.
      Ask FixBot
    2. Asus K53E-BBR3 Optical Drive Replacement: step 5, image 1 of 1
      • Gently pull the ribbon cable to the right and out of its port.
      Ask FixBot
    1. Asus K53E-BBR3 Optical Drive Replacement, Optical Drive: step 6, image 1 of 3 Asus K53E-BBR3 Optical Drive Replacement, Optical Drive: step 6, image 2 of 3 Asus K53E-BBR3 Optical Drive Replacement, Optical Drive: step 6, image 3 of 3
      • On the back of the laptop unscrew the eighteen 5mm Phillips #1 screws.
      • Unscrew the two 5mm Phillips #1 screws.
      • The screws highlighted in orange are slightly thicker than those in red, however they are the same length and head type.
      Ask FixBot
    2. Asus K53E-BBR3 Optical Drive Replacement: step 7, image 1 of 2 Asus K53E-BBR3 Optical Drive Replacement: step 7, image 2 of 2
      • Unscrew the four highlighted 5mm Phillips #1 screws, and remove the hard drive.
      • Unscrew the 3mm Phillips #1 screw.
      Ask FixBot
    3. Asus K53E-BBR3 Optical Drive Replacement: step 8, image 1 of 1
      • Flip the laptop over and remove the seven 5mm Phillips #1 screws.
      Ask FixBot
    4. Asus K53E-BBR3 Optical Drive Replacement: step 9, image 1 of 2 Asus K53E-BBR3 Optical Drive Replacement: step 9, image 2 of 2
      • There is a ribbon connector that is connecting the two halves of the laptop. So when opening the two plastic pieces be careful not to damage the cable.
      • Using the plastic opening tool, firmly pry apart the two sections of plastic.
      • Firmly shimmy the opening tool around the laptop prying the two sections of plastic apart.
      • Disconnect the highlighted ribbon cable, by pulling up on the black tab and gently pulling the cable out of its port.
      Ask FixBot
    5. Asus K53E-BBR3 Optical Drive Replacement: step 10, image 1 of 2 Asus K53E-BBR3 Optical Drive Replacement: step 10, image 2 of 2
      • Unscrew the three 3mm Phillips #0 screws.
      • Slide the optical drive to the right.
      • Remove the optical drive.
      Ask FixBot
Jacob O'Donnell
323 Reputation
3 Guides authored
UMass Dartmouth, Team 1-1, Catania Fall 2016 Member of UMass Dartmouth, Team 1-1, Catania Fall 2016
UMASSD-CATANIA-F16S1G1
3 Members
83 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 38
All Time: 1,035
