Asus K50IJ Fan Replacement
    1. Asus K50IJ Fan Replacement, Battery: step 1, image 1 of 1
      • Slide the tab over to unlock the battery cover located on the bottom-left corner of the laptop.
      Ask FixBot
    2. Asus K50IJ Fan Replacement: step 2, image 1 of 3 Asus K50IJ Fan Replacement: step 2, image 2 of 3 Asus K50IJ Fan Replacement: step 2, image 3 of 3
      • Lift the exposed lip and remove the battery cover.
      Ask FixBot
    3. Asus K50IJ Fan Replacement: step 3, image 1 of 3 Asus K50IJ Fan Replacement: step 3, image 2 of 3 Asus K50IJ Fan Replacement: step 3, image 3 of 3
      • Press the tabs on the battery and lift them. The battery should come out easily.
      Ask FixBot
    1. Asus K50IJ Fan Replacement, Fan: step 4, image 1 of 3 Asus K50IJ Fan Replacement, Fan: step 4, image 2 of 3 Asus K50IJ Fan Replacement, Fan: step 4, image 3 of 3
      • Using the PH1 screwdriver, remove the four 4 .75 mm screws that are located on the vent panel.
      Ask FixBot
    2. Asus K50IJ Fan Replacement: step 5, image 1 of 1
      • Remove the one .5 mm screw located in the top right corner of the battery compartment.
      Ask FixBot
    3. Asus K50IJ Fan Replacement: step 6, image 1 of 2 Asus K50IJ Fan Replacement: step 6, image 2 of 2
      • Remove the bottom panel by sliding it toward the hinges and lifting the back panel up.
      Ask FixBot
    4. Asus K50IJ Fan Replacement: step 7, image 1 of 1
      • Unplug the wire cable attached to the fan by pulling it out .
      Ask FixBot
    5. Asus K50IJ Fan Replacement: step 8, image 1 of 2 Asus K50IJ Fan Replacement: step 8, image 2 of 2
      • Using the PH1 screwdriver, remove the 3 .75mm screws labeled as 1, 2, and 3 on the fan. NOTE these screws have the labels "1", "2", and "3" next to them.
      • Lift the fan up with your fingers.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 98
All Time: 1,357
