Asus GL551JW-AH71 RAM Replacement
    1. Asus GL551JW-AH71 RAM Replacement, Battery: step 1, image 1 of 1
      • Close the device and lay it upside down.
      • Unplug the device and make sure the device is powered off before removing the battery.
      Ask FixBot
    2. Asus GL551JW-AH71 RAM Replacement: step 2, image 1 of 2 Asus GL551JW-AH71 RAM Replacement: step 2, image 2 of 2
      • Move the battery eject button to the right. The battery will be ejected.
      Ask FixBot
    3. Asus GL551JW-AH71 RAM Replacement: step 3, image 1 of 2 Asus GL551JW-AH71 RAM Replacement: step 3, image 2 of 2
      • Grab the battery and remove it from the device.
      Ask FixBot
    1. Asus GL551JW-AH71 RAM Replacement, RAM: step 4, image 1 of 2 Asus GL551JW-AH71 RAM Replacement, RAM: step 4, image 2 of 2
      • Using a Phillips #00 screwdriver, remove the two 11mm screws that hold the access panel in place.
      Ask FixBot
    2. Asus GL551JW-AH71 RAM Replacement: step 5, image 1 of 1
      • Remove the access panel by lifting it up.
      Ask FixBot
    3. Asus GL551JW-AH71 RAM Replacement: step 6, image 1 of 3 Asus GL551JW-AH71 RAM Replacement: step 6, image 2 of 3 Asus GL551JW-AH71 RAM Replacement: step 6, image 3 of 3
      • Locate the tabs holding the RAM chip in place.
      • Push the tabs in an outward direction from the RAM and the RAM will be released.
      • Gently remove the RAM from the motherboard.
      Ask FixBot
2 other people completed this guide.
William Kelley
1,035 Reputation
7 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 57
All Time: 570
