Asus GL551JW-AH71 Display Assembly Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
63
All Time:
1,249
Comments: 1
1 comment on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
This guide outlines how to replace the display assembly for the Asus GL551JW-AH71.
Tools
    1. Asus GL551JW-AH71 Display Assembly Replacement, Battery: step 1, image 1 of 1
      • Close the device and lay it upside down.
      • Unplug the device and make sure the device is powered off before removing the battery.
      Ask FixBot
    2. Asus GL551JW-AH71 Display Assembly Replacement: step 2, image 1 of 2 Asus GL551JW-AH71 Display Assembly Replacement: step 2, image 2 of 2
      • Move the battery eject button to the right. The battery will be ejected.
      Ask FixBot
    3. Asus GL551JW-AH71 Display Assembly Replacement: step 3, image 1 of 2 Asus GL551JW-AH71 Display Assembly Replacement: step 3, image 2 of 2
      • Grab the battery and remove it from the device.
      Ask FixBot
    1. Asus GL551JW-AH71 Display Assembly Replacement, Optical Drive: step 4, image 1 of 2 Asus GL551JW-AH71 Display Assembly Replacement, Optical Drive: step 4, image 2 of 2
      • Use a Phillips #000 screwdriver to remove the single 10mm optical drive screw.
      Ask FixBot
    2. Asus GL551JW-AH71 Display Assembly Replacement: step 5, image 1 of 3 Asus GL551JW-AH71 Display Assembly Replacement: step 5, image 2 of 3 Asus GL551JW-AH71 Display Assembly Replacement: step 5, image 3 of 3
      • Insert a probe or paperclip gently into the eject pin hole to eject the optical drive tray.
      Ask FixBot
    3. Asus GL551JW-AH71 Display Assembly Replacement: step 6, image 1 of 2 Asus GL551JW-AH71 Display Assembly Replacement: step 6, image 2 of 2
      • Gently grasp the optical drive assembly and slide it out of the laptop body.
      Ask FixBot
    1. Asus GL551JW-AH71 Display Assembly Replacement, Upper Assembly: step 7, image 1 of 2 Asus GL551JW-AH71 Display Assembly Replacement, Upper Assembly: step 7, image 2 of 2
      • Using a Phillips #000 screwdriver, remove the two 11mm screws that hold the access panel in place.
      Ask FixBot
    2. Asus GL551JW-AH71 Display Assembly Replacement: step 8, image 1 of 2 Asus GL551JW-AH71 Display Assembly Replacement: step 8, image 2 of 2
      • Carefully remove the access panel.
      Ask FixBot
    3. Asus GL551JW-AH71 Display Assembly Replacement: step 9, image 1 of 2 Asus GL551JW-AH71 Display Assembly Replacement: step 9, image 2 of 2
      • Using a Phillips #000 screwdriver, remove the seven 11mm screws holding lower case to the laptop.
      Ask FixBot
    4. Asus GL551JW-AH71 Display Assembly Replacement: step 10, image 1 of 1
      • Turn the laptop over and open the screen.
      Ask FixBot
    5. Asus GL551JW-AH71 Display Assembly Replacement: step 11, image 1 of 3 Asus GL551JW-AH71 Display Assembly Replacement: step 11, image 2 of 3 Asus GL551JW-AH71 Display Assembly Replacement: step 11, image 3 of 3
      • Gently pry open the case with an iFixit opening tool.
      • The upper and lower assembly are connected with a display cable that will be removed in the next step. Do not pull the parts apart more than a few inches.
      Ask FixBot
    6. Asus GL551JW-AH71 Display Assembly Replacement: step 12, image 1 of 3 Asus GL551JW-AH71 Display Assembly Replacement: step 12, image 2 of 3 Asus GL551JW-AH71 Display Assembly Replacement: step 12, image 3 of 3
      • Flip the laptop on the right side while still holding the upper and lower assemblies close together.
      • Unplug the display connector from the motherboard.
      • Remove the upper assembly.
      Ask FixBot
    1. Asus GL551JW-AH71 Display Assembly Replacement, Display Assembly: step 13, image 1 of 2 Asus GL551JW-AH71 Display Assembly Replacement, Display Assembly: step 13, image 2 of 2
      • Remove the three 5mm screws located in each circle with a Phillips #000 screwdriver.
      • A total of twelve 5mm screw should be removed in order to free the display assembly from the base.
      Ask FixBot
    2. Asus GL551JW-AH71 Display Assembly Replacement: step 14, image 1 of 2 Asus GL551JW-AH71 Display Assembly Replacement: step 14, image 2 of 2
      • Lift the display assembly up, separating it from the base of the device.
      Ask FixBot
    3. Asus GL551JW-AH71 Display Assembly Replacement: step 15, image 1 of 3 Asus GL551JW-AH71 Display Assembly Replacement: step 15, image 2 of 3 Asus GL551JW-AH71 Display Assembly Replacement: step 15, image 3 of 3
      • Using a plastic opening tool, separate the bezel from the screen.
      • Insert the tool and slide it right to left to release the bezel from the screen.
      Ask FixBot
    4. Asus GL551JW-AH71 Display Assembly Replacement: step 16, image 1 of 2 Asus GL551JW-AH71 Display Assembly Replacement: step 16, image 2 of 2
      • Remove the four screws using a Phillips #0 screwdriver.
      Ask FixBot
    5. Asus GL551JW-AH71 Display Assembly Replacement: step 17, image 1 of 2 Asus GL551JW-AH71 Display Assembly Replacement: step 17, image 2 of 2
      • Grab the screen in the corners and lift up to remove it.
      Ask FixBot
3 other people completed this guide.
Alec Pimentel
258 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 63
All Time: 1,249
