Asus G74SX-BBK7 Trackpad Button Replacement
    1. Asus G74SX-BBK7 Trackpad Button Replacement, Optical Drive: step 1, image 1 of 1
      • Using a flathead screwdriver, spudger, or large coin such as a quarter, remove the 13mm screw on the bottom of the laptop.
      • Take off the back panel.
      Ask FixBot
    2. Asus G74SX-BBK7 Trackpad Button Replacement: step 2, image 1 of 1
      • Now, unscrew and remove the 6mm Phillips #0 screw next to the optical drive.
      Ask FixBot
    3. Asus G74SX-BBK7 Trackpad Button Replacement: step 3, image 1 of 2 Asus G74SX-BBK7 Trackpad Button Replacement: step 3, image 2 of 2
      • Lastly, use a plastic opening tool to remove the optical drive from its slot.
      Ask FixBot
    1. Asus G74SX-BBK7 Trackpad Button Replacement, Trackpad Button: step 4, image 1 of 1
      • Remove the two 6mm Phillips #0 screws that were previously covered by the optical drive using a Phillips #0 screwdriver.
      Ask FixBot
    2. Asus G74SX-BBK7 Trackpad Button Replacement: step 5, image 1 of 1
      • First, remove the five 10mm Phillips #0 screws from the back of the computer near the top.
      • Remove all eighteen 6mm Phillips #0 screws from the bottom of the computer.
      • Some of the screws are set very deeply in the back case - you will need a long and narrow screwdriver to remove them.
      Ask FixBot
    3. Asus G74SX-BBK7 Trackpad Button Replacement: step 6, image 1 of 2 Asus G74SX-BBK7 Trackpad Button Replacement: step 6, image 2 of 2
      • Next, pry open back plastic cover using a metal spudger.
      • Unscrew the four 10mm Phillips #0 screws under the cover.
      Ask FixBot
    4. Asus G74SX-BBK7 Trackpad Button Replacement: step 7, image 1 of 3 Asus G74SX-BBK7 Trackpad Button Replacement: step 7, image 2 of 3 Asus G74SX-BBK7 Trackpad Button Replacement: step 7, image 3 of 3
      • Lay laptop opened and completely flat.
      • Using the metal spudger, slowly pry open the front main panel by going around each side.
      • Lift the top panel out, pulling the cable strips out of their sockets. These will be reattached later.
      • Be careful when lifting the top panel. There are cable strips attached to the motherboard that need to be removed.
      Ask FixBot
    5. Asus G74SX-BBK7 Trackpad Button Replacement: step 8, image 1 of 2 Asus G74SX-BBK7 Trackpad Button Replacement: step 8, image 2 of 2
      • After separating the main panel and the motherboard, unscrew two 6mm Phillips #0 screws.
      • Remove the mouse button.
      Ask FixBot
    6. Asus G74SX-BBK7 Trackpad Button Replacement: step 9, image 1 of 3 Asus G74SX-BBK7 Trackpad Button Replacement: step 9, image 2 of 3 Asus G74SX-BBK7 Trackpad Button Replacement: step 9, image 3 of 3
      • To reconnect the motherboard and main panel, insert strips back to their corresponding location.
      • To do this, first remove the tape and open up the tab. Plug in the strip and and close the tab.
      • It may be helpful to have someone help you hold the main panel while you reconnect the strips.
      Ask FixBot
2 other people completed this guide.
Ryan Lawrence
611 Reputation
5 Guides authored
Cal Poly, Team 5-10, Maness Spring 2015 Member of Cal Poly, Team 5-10, Maness Spring 2015
CPSU-MANESS-S15S5G10
4 Members
72 Guides authored
1 Guide Comment
Where did you find the part?
websmiths - Reply Share
Past 24 Hours: 3
Past 7 Days: 26
Past 30 Days: 98
All Time: 5,492
