Asus G74SX-BBK7 RAM Replacement
    1. Asus G74SX-BBK7 RAM Replacement, RAM: step 1, image 1 of 1
      • Using a flathead screwdriver, spudger, or large coin such as a quarter, remove the large 13mm screw on the bottom of the laptop.
      • Take off the back panel.
      Ask FixBot
    2. Asus G74SX-BBK7 RAM Replacement: step 2, image 1 of 3 Asus G74SX-BBK7 RAM Replacement: step 2, image 2 of 3 Asus G74SX-BBK7 RAM Replacement: step 2, image 3 of 3
      Tool used on this step:
      Anti-Static Wrist Strap
      $7.95
      Buy
      • Locate the RAM near the center of the computer.
      • Push gently on the metal pins that are on both sides of the RAM sticks.
      • Before touching the RAM, discharge any built-up static by touching a metal surface or wearing an antistatic wrist strap.
      Ask FixBot
    3. Asus G74SX-BBK7 RAM Replacement: step 3, image 1 of 1
      • When you push on the pins, the RAM will pop up. Gently remove it from its socket.
      • Repeat the third and fourth step for the second stick of RAM, located behind the first stick.
      Ask FixBot
2 other people completed this guide.
Josiah Avery
131 Reputation
1 Guide authored
Cal Poly, Team 5-10, Maness Spring 2015 Member of Cal Poly, Team 5-10, Maness Spring 2015
CPSU-MANESS-S15S5G10
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 110
All Time: 1,318
