Asus G74SX-BBK7 Optical Drive Replacement
    1. Asus G74SX-BBK7 Optical Drive Replacement, Optical Drive: step 1, image 1 of 1
      • Using a flathead screwdriver, spudger, or large coin such as a quarter, remove the 13mm screw on the bottom of the laptop.
      • Take off the back panel.
      Ask FixBot
    2. Asus G74SX-BBK7 Optical Drive Replacement: step 2, image 1 of 1
      • Now, unscrew and remove the 6mm Phillips #0 screw next to the optical drive.
      Ask FixBot
    3. Asus G74SX-BBK7 Optical Drive Replacement: step 3, image 1 of 2 Asus G74SX-BBK7 Optical Drive Replacement: step 3, image 2 of 2
      • Lastly, use a plastic opening tool to remove the optical drive from its slot.
      Ask FixBot
4 other people completed this guide.
Ryan Lawrence
611 Reputation
5 Guides authored
Cal Poly, Team 5-10, Maness Spring 2015 Member of Cal Poly, Team 5-10, Maness Spring 2015
CPSU-MANESS-S15S5G10
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 105
All Time: 2,656
