Asus G73JW-XT1 Hard Drive Replacement
  1. Asus G73JW-XT1 Hard Drive Replacement, Battery: step 1, image 1 of 1
    • Flip the device over so the battery port is easy to access.
    Ask FixBot
  2. Asus G73JW-XT1 Hard Drive Replacement: step 2, image 1 of 2 Asus G73JW-XT1 Hard Drive Replacement: step 2, image 2 of 2
    • Slide the left slider to the left so that it locks in place.
    • Slide the right slider to the right while pushing the battery away from you. The battery should disconnect.
    Ask FixBot
  3. Asus G73JW-XT1 Hard Drive Replacement, Hard Drive: step 3, image 1 of 3 Asus G73JW-XT1 Hard Drive Replacement, Hard Drive: step 3, image 2 of 3 Asus G73JW-XT1 Hard Drive Replacement, Hard Drive: step 3, image 3 of 3
    • Remove the two 5.5 mm Phillips #0 screws from the back cover.
    • Gently lift and remove the back cover.
    Ask FixBot
  4. Asus G73JW-XT1 Hard Drive Replacement: step 4, image 1 of 3 Asus G73JW-XT1 Hard Drive Replacement: step 4, image 2 of 3 Asus G73JW-XT1 Hard Drive Replacement: step 4, image 3 of 3
    • Remove the four 5.5 mm Phillips #0 screws.
    • Gently lift the hard drive starting on the far side.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 19
All Time: 427
