Up to 20% off select tools
Asus G73JH-RBBX05 RAM Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
103
All Time:
1,384
Comments: 1
1 guide comment.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to remove and replace the RAM on the Asus G73JH-RBBX05.
    1. Asus G73JH-RBBX05 RAM Replacement, RAM: step 1, image 1 of 1
      • Locate the two, 4mm screws on the back of the laptop and remove them using a PH0 screwdriver.
      Ask FixBot
    2. Asus G73JH-RBBX05 RAM Replacement: step 2, image 1 of 1
      • Use the plastic spudger to remove the panel.
      Ask FixBot
    3. Asus G73JH-RBBX05 RAM Replacement: step 3, image 1 of 2 Asus G73JH-RBBX05 RAM Replacement: step 3, image 2 of 2
      • Push down the metal clips and remove the RAM.
      Ask FixBot
4 other people completed this guide.
Author
with
Trevor Sprosty
409 Reputation
3 Guides authored
Cal Poly, Team 22-11, Maness Winter 2017 Member of Cal Poly, Team 22-11, Maness Winter 2017
CPSU-MANESS-W17S22G11
3 Members
60 Guides authored
1 Guide Comment
Unfortunately, not very helpful when the only one that needs replacing is the only one not noted in this guide. Under the inside of the board, right behind the third RAM stick, there is a fourth that requires almost a total disassembly of the unit to access.
nekospacer - Reply Share
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 103
All Time: 1,384
