Up to 20% off select tools
Asus G73JH-RBBX05 Keyboard Replacement
Views: 2.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
15
Past 30 Days:
86
All Time:
2,600
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 minute
Difficulty: Easy
Parts
Tools
  • Metal Spudger
    $2.99
    4.9
  • Spudger
    4.9
Introduction
Go to step 1 ↓
Use this guide to remove the keyboard on the Asus G73JH-RBBX05.
    1. Asus G73JH-RBBX05 Keyboard Replacement, Keyboard: step 1, image 1 of 2 Asus G73JH-RBBX05 Keyboard Replacement, Keyboard: step 1, image 2 of 2
      • Locate the 5 clips located at the top of the keyboard. Insert a metal spudger into the clip openings on the keyboard to remove the keyboard.
      Ask FixBot
    2. Asus G73JH-RBBX05 Keyboard Replacement: step 2, image 1 of 3 Asus G73JH-RBBX05 Keyboard Replacement: step 2, image 2 of 3 Asus G73JH-RBBX05 Keyboard Replacement: step 2, image 3 of 3
      • Before fully removing the keyboard, remove the back lighting cable and keyboard data strip.
      • In order to remove these cables, push forward the black retention clips and pull out the cables.
      Ask FixBot
Author
with
Josh DeBest
390 Reputation
2 Guides authored
Cal Poly, Team 22-11, Maness Winter 2017 Member of Cal Poly, Team 22-11, Maness Winter 2017
CPSU-MANESS-W17S22G11
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 86
All Time: 2,600
