Asus G73JH-RBBX05 Hard Drive Replacement
    1. Asus G73JH-RBBX05 Hard Drive Replacement, Hard Drive: step 1, image 1 of 1
      • Flip the laptop over and remove the two 4mm screws located at the bottom of the laptop with the PH0 screwdriver.
      Ask FixBot
    2. Asus G73JH-RBBX05 Hard Drive Replacement: step 2, image 1 of 1
      • Using a plastic opening tool or finger, remove the access panel.
      • Apply constant force until the panel releases from the clips underneath.
      Ask FixBot
    3. Asus G73JH-RBBX05 Hard Drive Replacement: step 3, image 1 of 1
      • Locate the two, 4mm screws on the hard drive. Remove them with the PH0 screwdriver.
      Ask FixBot
    4. Asus G73JH-RBBX05 Hard Drive Replacement: step 4, image 1 of 1
      • Using the black tab located on the hard drive, pull out the hard drive.
      Ask FixBot
Trevor Sprosty
409 Reputation
3 Guides authored
Cal Poly, Team 22-11, Maness Winter 2017 Member of Cal Poly, Team 22-11, Maness Winter 2017
CPSU-MANESS-W17S22G11
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 99
All Time: 1,267
