Up to 20% off select tools
Asus G73JH-RBBX05 Fan Replacement
Views: 2.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
94
All Time:
2,256
Comments: 1
1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Difficult
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide will help you access the fans in order to clean or replace them.
Tools needed: size 0 Phillips head screwdriver, opening tool, metal spudger
    1. Asus G73JH-RBBX05 Fan Replacement, Keyboard: step 1, image 1 of 2 Asus G73JH-RBBX05 Fan Replacement, Keyboard: step 1, image 2 of 2
      • Locate the 5 clips located at the top of the keyboard. Insert a metal spudger into the clip openings on the keyboard to remove the keyboard.
      Ask FixBot
    2. Asus G73JH-RBBX05 Fan Replacement: step 2, image 1 of 3 Asus G73JH-RBBX05 Fan Replacement: step 2, image 2 of 3 Asus G73JH-RBBX05 Fan Replacement: step 2, image 3 of 3
      • Before fully removing the keyboard, remove the back lighting cable and keyboard data strip.
      • In order to remove these cables, push forward the black retention clips and pull out the cables.
      Ask FixBot
    1. Asus G73JH-RBBX05 Fan Replacement, Fan: step 3, image 1 of 1
      • Remove the 4mm screws located under the keyboard with the PH0 screwdriver.
      Ask FixBot
    2. Asus G73JH-RBBX05 Fan Replacement: step 4, image 1 of 2 Asus G73JH-RBBX05 Fan Replacement: step 4, image 2 of 2
      • Using a PH0 screwdriver, remove the two, 4mm screws .
      • Using either your finger or a plastic opening tool, remove the back panel.
      Ask FixBot
    3. Asus G73JH-RBBX05 Fan Replacement: step 5, image 1 of 1
      • Using the PH0 screwdriver, remove the nine, 4mm screws on the bottom of the laptop.
      • You must remove the two, 4mm screws located under the battery. Remove the battery by following these steps: Asus G73JH-RBBX05 Battery Replacement
      Ask FixBot
    4. Asus G73JH-RBBX05 Fan Replacement: step 6, image 1 of 1
      • Using a metal spudger, remove the back cover of the laptop.
      • Apply constant force in order to unhinged the panel.
      Ask FixBot
    5. Asus G73JH-RBBX05 Fan Replacement: step 7, image 1 of 2 Asus G73JH-RBBX05 Fan Replacement: step 7, image 2 of 2
      • Remove the four, 4mm screws located on both of the hinges using the PH0 screwdriver and flip open the device.
      • Make sure you do this step for both the left and right hinges.
      Ask FixBot
    6. Asus G73JH-RBBX05 Fan Replacement: step 8, image 1 of 2 Asus G73JH-RBBX05 Fan Replacement: step 8, image 2 of 2
      • Using a metal pry tool, remove the base cover
      • Once the cover is completely unhinged, don't forget to detach the strips connected to the motherboard.
      Ask FixBot
    7. Asus G73JH-RBBX05 Fan Replacement: step 9, image 1 of 3 Asus G73JH-RBBX05 Fan Replacement: step 9, image 2 of 3 Asus G73JH-RBBX05 Fan Replacement: step 9, image 3 of 3
      • Locate the fan and remove the three 2mm screws with the PH0 screwdriver.
      • Before removing the fan, disconnect the cable.
      Ask FixBot
3 other people completed this guide.
Author
with
Trevor Sprosty
409 Reputation
3 Guides authored
Cal Poly, Team 22-11, Maness Winter 2017 Member of Cal Poly, Team 22-11, Maness Winter 2017
CPSU-MANESS-W17S22G11
3 Members
60 Guides authored
1 Guide Comment
Some steps missing, regarding screws to remove: 1 screw that holds optical drive; once that is removed, 2 screws in the drive compartment; 2 screws in the battery compartment; 3 screws from the bottom of the motherboard.
Byron Canfield - Reply Share
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 94
All Time: 2,256
