Asus F6A-X2 Bottom Access Panel Replacement
    1. Asus F6A-X2 Bottom Access Panel Replacement, Back Access Panel: step 1, image 1 of 2 Asus F6A-X2 Bottom Access Panel Replacement, Back Access Panel: step 1, image 2 of 2
      • With the laptop facing down, rotate it so the battery pack is facing away from you.
      • Remove the six 1.5 mm Phillips #1 screws on the back panel of the laptop.
      Ask FixBot
    2. Asus F6A-X2 Bottom Access Panel Replacement: step 2, image 1 of 3 Asus F6A-X2 Bottom Access Panel Replacement: step 2, image 2 of 3 Asus F6A-X2 Bottom Access Panel Replacement: step 2, image 3 of 3
      • Insert a finger into one of the slots on the bottom panel.
      • Gently lift the upwards, and the back panel of the laptop will come off easily.
      Ask FixBot
Mikel Sangroniz
192 Reputation
1 Guide authored
Cal Poly, Team 10-56, Amido Spring 2014 Member of Cal Poly, Team 10-56, Amido Spring 2014
CPSU-AMIDO-S14S10G56
4 Members
144 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 31
Past 30 Days: 112
All Time: 1,480
