Asus F555LA-AB31 Network Card Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
Past 7 Days:
17
Past 30 Days:
71
All Time:
1,135
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 25 - 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If your Asus F555LA-AB31 will not connect to the network or if you experience intermittent connections, it may be time to replace your network card. Your network card connects your computer to a local area network (LAN) or the internet. If the network card has a faulty hardware component, the operating system might not show it as a connected device. It may also not reliably connect to networks or recognize networks in specific situations; such as when the laptop is hot or during extended use.
Before using this guide, verify the issue is not software related before replacing the network card. Asus provides a support guide to troubleshooting wireless issues in this link.
Electronics are sensitive to ESD. Here is a link for using an anti-static mat and wristband. The laptop must be unplugged before servicing to prevent electrical shock and hardware damage.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
    1. Asus F555LA-AB31 Network Card Replacement, CD Drive: step 1, image 1 of 1
      • Turn off and unplug the device before starting repairing.
      • Use the Phillips #0 screwdriver head to remove the ten 18mm Phillips #0 screws on the laptop's bottom.
      Ask FixBot
    2. Asus F555LA-AB31 Network Card Replacement: step 2, image 1 of 2 Asus F555LA-AB31 Network Card Replacement: step 2, image 2 of 2
      • Flip the laptop over and flip the screen up.
      • Pry upward on the edges of the faceplate in order to separate the keyboard and trackpad from the rest of the device.
      • Be cautious of the cables connecting the keyboard and trackpad to the motherboard.
      Ask FixBot
    3. Asus F555LA-AB31 Network Card Replacement: step 3, image 1 of 1
      • Disconnect the keyboard flex cable from its motherboard ZIF socket.
      • To unlock a ZIF connector, use the tip of a spudger or your fingernail to flip up the small, hinged locking flap. Carefully slide the unlocked cable out of the socket.
      Ask FixBot
    4. Asus F555LA-AB31 Network Card Replacement: step 4, image 1 of 2 Asus F555LA-AB31 Network Card Replacement: step 4, image 2 of 2
      • Use the Phillips #0 screwdriver to unscrew the one Phillips #0 screw that connects the CD drive to the motherboard.
      • Slowly slide out the CD drive, keeping it level, to remove it.
      Ask FixBot
    1. Asus F555LA-AB31 Network Card Replacement, Hard Drive: step 5, image 1 of 1
      • Remove ten 18mm Phillips #0 screws from the backside of the device.
      • Removal of the RAM access panel is not necessary.
      Ask FixBot
    2. Asus F555LA-AB31 Network Card Replacement: step 6, image 1 of 3 Asus F555LA-AB31 Network Card Replacement: step 6, image 2 of 3 Asus F555LA-AB31 Network Card Replacement: step 6, image 3 of 3
      • Carefully fold the device open.
      • Begin to pry upward on the edges of the faceplate in order to separate the keyboard and trackpad from the rest of the device.
      • To remove the ZIF connector, gently lift upward on the blue tab to disconnect it from the motherboard.
      Ask FixBot
    3. Asus F555LA-AB31 Network Card Replacement: step 7, image 1 of 3 Asus F555LA-AB31 Network Card Replacement: step 7, image 2 of 3 Asus F555LA-AB31 Network Card Replacement: step 7, image 3 of 3
      • Fold the keyboard section of the laptop up towards the screen to fully expose the inside of the device.
      • Unscrew the four 4mm Phillips #0 screws holding down the hard drive.
      Ask FixBot
    4. Asus F555LA-AB31 Network Card Replacement: step 8, image 1 of 1
      • Disconnect the ZIF connector and lift the hard drive out of the space.
      Ask FixBot
    1. Asus F555LA-AB31 Network Card Replacement, Battery: step 9, image 1 of 2 Asus F555LA-AB31 Network Card Replacement, Battery: step 9, image 2 of 2
      • Remove the four 4 mm Phillips #0 screws securing the battery.
      Ask FixBot
    2. Asus F555LA-AB31 Network Card Replacement: step 10, image 1 of 2 Asus F555LA-AB31 Network Card Replacement: step 10, image 2 of 2
      • Lift up battery and remove it from the device.
      Ask FixBot
    1. Asus F555LA-AB31 Network Card Replacement, Network Card: step 11, image 1 of 1
      • Disconnect the two wires connected to the network card.
      Ask FixBot
    2. Asus F555LA-AB31 Network Card Replacement: step 12, image 1 of 3 Asus F555LA-AB31 Network Card Replacement: step 12, image 2 of 3 Asus F555LA-AB31 Network Card Replacement: step 12, image 3 of 3
      • Remove the seven Phillips #0 screws holding the motherboard down.
      • Lift the motherboard upwards, folding it towards the laptop chassis.
      • Unscrew the Phillips #0 screw holding down the network card, and slide it out.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 71
All Time: 1,135
