Asus F554LA-WS52 Touchpad Replacement
    1. Asus F554LA-WS52 Touchpad Replacement, Touchpad: step 1, image 1 of 3 Asus F554LA-WS52 Touchpad Replacement, Touchpad: step 1, image 2 of 3 Asus F554LA-WS52 Touchpad Replacement, Touchpad: step 1, image 3 of 3
      • Make sure your notebook device is unplugged and turned off before opening it up.
      • Flip the notebook over and remove the 10 screws from the back plate with a #0 Phillips head screwdriver.
      • Six (6) will be 9.6mm and four (4) will be 12.7mm.
      Ask FixBot
    2. Asus F554LA-WS52 Touchpad Replacement: step 2, image 1 of 3 Asus F554LA-WS52 Touchpad Replacement: step 2, image 2 of 3 Asus F554LA-WS52 Touchpad Replacement: step 2, image 3 of 3
      • Once the screws are removed, carefully lift both sides of the plastic keyboard/touch pad cover with a plastic opening tool.
      Ask FixBot
    3. Asus F554LA-WS52 Touchpad Replacement: step 3, image 1 of 1
      • Lift the plastic cover and unplug the three data cords (not all pictured) under the cover from the keyboard and motherboard.
      Ask FixBot
    4. Asus F554LA-WS52 Touchpad Replacement: step 4, image 1 of 3 Asus F554LA-WS52 Touchpad Replacement: step 4, image 2 of 3 Asus F554LA-WS52 Touchpad Replacement: step 4, image 3 of 3
      • Once you've removed the plastic cover, flip it over.
      • Next, carefully remove the tape from the bottom side of your touch pad.
      Ask FixBot
    5. Asus F554LA-WS52 Touchpad Replacement: step 5, image 1 of 1
      • Locate and unscrew the three 3.2 mm at the top edge of the touch pad using the Phillips #0 screwdriver.
      Ask FixBot
    6. Asus F554LA-WS52 Touchpad Replacement: step 6, image 1 of 3 Asus F554LA-WS52 Touchpad Replacement: step 6, image 2 of 3 Asus F554LA-WS52 Touchpad Replacement: step 6, image 3 of 3
      • Gently push the front of the touch pad with your finger to remove it from its position within the keyboard.
      • Replace touch pad.
      Ask FixBot
Clint Eagle
312 Reputation
1 Guide authored
USF Tampa, Team S1-G2, Leahy Fall 2018 Member of USF Tampa, Team S1-G2, Leahy Fall 2018
USFT-LEAHY-F18S1G2
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 26
Past 30 Days: 78
All Time: 745
