Up to 20% off select tools
Asus F554LA-WS52 Keyboard Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
12
Past 30 Days:
57
All Time:
814
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
If you have updated your keyboard drivers and the keyboard is still unresponsive, you can use this guide to replace it. You will need a Phillips #0 screwdriver and a plastic opening tool.
    1. Asus F554LA-WS52 Keyboard Replacement, Keyboard: step 1, image 1 of 2 Asus F554LA-WS52 Keyboard Replacement, Keyboard: step 1, image 2 of 2
      • Make sure the notebook is off and has been unplugged from any power source.
      • Flip the notebook over and remove the 10 screws from the back plate with a #0 Phillips head screwdriver.
      • Six (6) will be 9.6mm and four (4) will be 12.7mm.
      Ask FixBot
    2. Asus F554LA-WS52 Keyboard Replacement: step 2, image 1 of 3 Asus F554LA-WS52 Keyboard Replacement: step 2, image 2 of 3 Asus F554LA-WS52 Keyboard Replacement: step 2, image 3 of 3
      • Flip the notebook back over.
      • Gently lift and remove the keyboard with a plastic opening tool.
      Ask FixBot
    3. Asus F554LA-WS52 Keyboard Replacement: step 3, image 1 of 1
      • (Not pictured) Remove the three cables attached to the keyboard and one from the touch-pad.
      • (Not pictured) With the plastic opening tool, pry off the metal separation plate from the keyboard.
      • (Not pictured) With the plastic opening tool, gently pry the keyboard from its position and replace.
      Ask FixBot
Author
with
Aaron Ratliff
542 Reputation
4 Guides authored
USF Tampa, Team S1-G2, Leahy Fall 2018 Member of USF Tampa, Team S1-G2, Leahy Fall 2018
USFT-LEAHY-F18S1G2
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 57
All Time: 814
