Asus EeeBook X205TA TrackPad Replacement
Views: 2.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
92
All Time:
2,359
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 25 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will help you replace your Asus EeeBook X205TA trackpad in case it is damaged, not working, or worn out. If disposing trackpad, please follow the laws and regulations for proper disposal.
Tools
    1. Asus EeeBook X205TA TrackPad Replacement, TrackPad: step 1, image 1 of 2 Asus EeeBook X205TA TrackPad Replacement, TrackPad: step 1, image 2 of 2
      • Remove ten Phillips #00 screws located on the bottom of the laptop:
      • Seven short screws.
      • Three long screws.
      Ask FixBot
    2. Asus EeeBook X205TA TrackPad Replacement: step 2, image 1 of 1
      • Insert the plastic opening tool in the crevice between the back of the laptop and the rest of the case (where the hinge is).
      • Carefully pry open the case from several points.
      • Slowly remove the back of the laptop, revealing the parts inside.
      Ask FixBot
    3. Asus EeeBook X205TA TrackPad Replacement: step 3, image 1 of 2 Asus EeeBook X205TA TrackPad Replacement: step 3, image 2 of 2
      • Using the 2mm Phillips Screwdriver, carefully unscrew the four screws holding the track pad.
      • Using the Phillips #00 Screwdriver, unscrew the three screws holding the track pad.
      Ask FixBot
    4. Asus EeeBook X205TA TrackPad Replacement: step 4, image 1 of 1
      • Unplug the ZIF connector
      Ask FixBot
    5. Asus EeeBook X205TA TrackPad Replacement: step 5, image 1 of 1
      • Carefully pull the track pad from the side
      Ask FixBot
2 other people completed this guide.
Lorena Santiago
760 Reputation
4 Guides authored
USF Tampa, Team 2-2, Sullivan Fall 2016 Member of USF Tampa, Team 2-2, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G2
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 92
All Time: 2,359
