Asus EeeBook X205TA LED Screen Panel Chip Replacement
    1. Asus EeeBook X205TA LED Screen Panel Chip Replacement, Battery: step 1, image 1 of 2 Asus EeeBook X205TA LED Screen Panel Chip Replacement, Battery: step 1, image 2 of 2
      • Unscrew all ten 2mm screws located on the bottom of the laptop using a Phillips #2 screwdriver.
      Ask FixBot
    2. Asus EeeBook X205TA LED Screen Panel Chip Replacement: step 2, image 1 of 1
      • Insert the plastic opening tool in the crevice between the back of the laptop and the rest of the case.
      • Carefully pry open the case from several points.
      • Slowly remove the back of the laptop, revealing the parts inside.
      Ask FixBot
    3. Asus EeeBook X205TA LED Screen Panel Chip Replacement: step 3, image 1 of 2 Asus EeeBook X205TA LED Screen Panel Chip Replacement: step 3, image 2 of 2
      • Unscrew all six 2mm screws using Philips #2 screws along the edges of the L-Shaped battery.
      • Any tape or cords that run along the battery should be carefully pushed to the side.
      Ask FixBot
    4. Asus EeeBook X205TA LED Screen Panel Chip Replacement: step 4, image 1 of 1
      • Disconnect the battery from the motherboard by pulling the No-Fuss Ribbon cables out of the connector.
      Ask FixBot
    5. Asus EeeBook X205TA LED Screen Panel Chip Replacement: step 5, image 1 of 1
      • Carefully lift the battery out of the laptop.
      Ask FixBot
    1. Asus EeeBook X205TA LED Screen Panel Chip Replacement, LED Screen Panel Chip: step 6, image 1 of 1
      • Locate and lift the tabs from the LED/motherboard ribbon cable.
      • Remove the cable.
      Ask FixBot
    2. Asus EeeBook X205TA LED Screen Panel Chip Replacement: step 7, image 1 of 1
      • Unscrew the 1 JIS 2mm screw with the J0 bit.
      Ask FixBot
    3. Asus EeeBook X205TA LED Screen Panel Chip Replacement: step 8, image 1 of 1
      • Remove the chip.
      Ask FixBot
Rachael
125 Reputation
1 Guide authored
IUPUI, Team S3-G4, Baechle Spring 2017 Member of IUPUI, Team S3-G4, Baechle Spring 2017
IUPUI-BAECHLE-S17S3G4
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 36
All Time: 1,570
