Introduction
Go to step 1 ↓RAM acts as temporary storage on your device that will occasionally fault or run out of memory. If you need to replace or install new RAM on your Asus Eee PC 900, follow the directions below. Before beginning, make sure the device is powered off and is not connected to any power source.
Slide the battery's locking tabs from the locked position to unlocked positions.
Tool used on this step:Tweezers$4.99
Remove the sticker from the RAM compartment using a pair of tweezers.
5 other people completed this guide.
