Up to 20% off select tools
Asus Eee PC 1215N RAM Replacement
Views: 3.7K
View statistics:
Past 24 Hours:
4
Past 7 Days:
18
Past 30 Days:
90
All Time:
3,710
Comments: 2
2 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 3 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
    1. Asus Eee PC 1215N RAM Replacement, Battery: step 1, image 1 of 2 Asus Eee PC 1215N RAM Replacement, Battery: step 1, image 2 of 2
      • Turn the power off and turn the netbook upside down.
      • Slide both battery catches together to release the battery.
      • Slide the battery out.
      Ask FixBot
    1. Asus Eee PC 1215N RAM Replacement, RAM: step 2, image 1 of 3 Asus Eee PC 1215N RAM Replacement, RAM: step 2, image 2 of 3 Asus Eee PC 1215N RAM Replacement, RAM: step 2, image 3 of 3
      • Locate the memory compartment.
      • Using a Plastic Opening Tools, remove the screw rubber cover.
      • Remove the screw.
      Ask FixBot
    2. Asus Eee PC 1215N RAM Replacement: step 3, image 1 of 1
      • Use a Plastic Opening Tools near the screw hole to release the cover.
      • Remove the cover
      Ask FixBot
    3. Asus Eee PC 1215N RAM Replacement: step 4, image 1 of 2 Asus Eee PC 1215N RAM Replacement: step 4, image 2 of 2
      Tool used on this step:
      Spudger
      $3.99
      Buy
      • Using a Spudger, push both right and left metal clip to release one of the RAM module.
      • Slide out the RAM module.
      • Do the same with the second RAM module if necessary.
      Ask FixBot
Author
with
Gaetan
9,631 Reputation
18 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 90
All Time: 3,710
