Asus Eee PC 1215N Hard Drive Replacement
    1. Asus Eee PC 1215N Hard Drive Replacement, Battery: step 1, image 1 of 2 Asus Eee PC 1215N Hard Drive Replacement, Battery: step 1, image 2 of 2
      • Turn the power off and turn the netbook upside down.
      • Slide both battery catches together to release the battery.
      • Slide the battery out.
      Ask FixBot
    1. Asus Eee PC 1215N Hard Drive Replacement, RAM: step 2, image 1 of 3 Asus Eee PC 1215N Hard Drive Replacement, RAM: step 2, image 2 of 3 Asus Eee PC 1215N Hard Drive Replacement, RAM: step 2, image 3 of 3
      • Locate the memory compartment.
      • Using a Plastic Opening Tools, remove the screw rubber cover.
      • Remove the screw.
      Ask FixBot
    2. Asus Eee PC 1215N Hard Drive Replacement: step 3, image 1 of 1
      • Use a Plastic Opening Tools near the screw hole to release the cover.
      • Remove the cover
      Ask FixBot
    3. Asus Eee PC 1215N Hard Drive Replacement: step 4, image 1 of 2 Asus Eee PC 1215N Hard Drive Replacement: step 4, image 2 of 2
      Tool used on this step:
      Spudger
      $3.99
      Buy
      • Using a Spudger, push both right and left metal clip to release one of the RAM module.
      • Slide out the RAM module.
      • Do the same with the second RAM module if necessary.
      Ask FixBot
    1. Asus Eee PC 1215N Hard Drive Replacement, Top Cover (Touchpad): step 5, image 1 of 1
      • Remove the screws as necessary.
      • For top cover removing, only remove the 2 bottom screws.
      • For Keyboard removing, remove all 4 screws.
      • The one short screw paterns to uper left screw hole directly on the PCB.
      Ask FixBot
    2. Asus Eee PC 1215N Hard Drive Replacement: step 6, image 1 of 3 Asus Eee PC 1215N Hard Drive Replacement: step 6, image 2 of 3 Asus Eee PC 1215N Hard Drive Replacement: step 6, image 3 of 3
      • Use a Plastic Opening Tools to release the top cover.
      • Start from the left side.
      • Go around on the bottom
      • Finish with the right side.
      • The top cover is still connected to the PCB with the touchpad ribbon. Handle it carefully.
      Ask FixBot
    3. Asus Eee PC 1215N Hard Drive Replacement: step 7, image 1 of 2 Asus Eee PC 1215N Hard Drive Replacement: step 7, image 2 of 2
      Spudger
      $3.99
      Buy
      • Carefully slide the top cover to the bottom in order to see the touchpad connector on the PCB.
      • Use a Spudger to slide the conector attachment black part and release the ribbon from the PCB.
      • Now you can remove the top cover
      Ask FixBot
    1. Asus Eee PC 1215N Hard Drive Replacement, Keyboard: step 8, image 1 of 3 Asus Eee PC 1215N Hard Drive Replacement, Keyboard: step 8, image 2 of 3 Asus Eee PC 1215N Hard Drive Replacement, Keyboard: step 8, image 3 of 3
      • Make sure that the two upper screws inside the RAM compartment are removed before to continue. (Refer to Step 5).
      • Remove the keyboard 4 screws on the bottom.
      • Use a Plastic Opening Tools to release the keyboard clips on the left and right side.
      Ask FixBot
    2. Asus Eee PC 1215N Hard Drive Replacement: step 9, image 1 of 1
      Spudger
      $3.99
      Buy
      • At this step, the keyboard is still maintained with double-sided tape between the keyboard underside and the metallic PCB protector.
      • Carefully slide a Spudger between the keyboard underside and the metallic PCB protector near the center/right at the bottom. Use the spudger as a lever to release the keyboard from the metallic PCB protector.
      • The keyboard is still connected to the PCB with a ribbon. Handle it carefully.
      Ask FixBot
    3. Asus Eee PC 1215N Hard Drive Replacement: step 10, image 1 of 2 Asus Eee PC 1215N Hard Drive Replacement: step 10, image 2 of 2
      Spudger
      $3.99
      Buy
      • Carefully slide the keyboard to the top in order to see the ribbon connector on the PCB.
      • Use a Spudger to slide the connector attachment black part and release the ribbon from the PCB.
      • Now you can remove the keyboard.
      Ask FixBot
    1. Asus Eee PC 1215N Hard Drive Replacement, Metallic PCB protector plate: step 11, image 1 of 3 Asus Eee PC 1215N Hard Drive Replacement, Metallic PCB protector plate: step 11, image 2 of 3 Asus Eee PC 1215N Hard Drive Replacement, Metallic PCB protector plate: step 11, image 3 of 3
      • Peel off the protective tape at the bottom left corner.
      • Peel off the warranty void at the bottom right corner and remove the screw below.
      • Remove the 6 other screws.
      Ask FixBot
    2. Asus Eee PC 1215N Hard Drive Replacement: step 12, image 1 of 2 Asus Eee PC 1215N Hard Drive Replacement: step 12, image 2 of 2
      • Remove the protector plate.
      Ask FixBot
    1. Asus Eee PC 1215N Hard Drive Replacement, Hard Drive: step 13, image 1 of 3 Asus Eee PC 1215N Hard Drive Replacement, Hard Drive: step 13, image 2 of 3 Asus Eee PC 1215N Hard Drive Replacement, Hard Drive: step 13, image 3 of 3
      • Remove the four Phillips #00 screws from the hard drive caddy.
      • Peel off any tape covering the hard drive, there is no need to remove it entirely.
      Ask FixBot
    2. Asus Eee PC 1215N Hard Drive Replacement: step 14, image 1 of 3 Asus Eee PC 1215N Hard Drive Replacement: step 14, image 2 of 3 Asus Eee PC 1215N Hard Drive Replacement: step 14, image 3 of 3
      • Unplug the hard drive by sliding it to the right, toward the USB ports.
      • Remove the hard drive.
      Ask FixBot
25 other people completed this guide.
Gaetan
9,613 Reputation
18 Guides authored
7 Guide Comments
I've just upgraded my 1215N HDD using this guide. This is very good step by step guide. A WIndows 10 Pro install managed to wreck the pre-installed HDD.
Like Tolidano , I just used a normal flat head screwdriver and a Philips screwdriver to carry out the HDD swap. I'm now in the process of installing Windows 10 Pro on to the new HDD.
Richard Bijster - Reply Share
Very good guide! I my case i need to remove 2 screws from the battery compartment to remove the keyboard
gus - Reply Share
I also had to remove the two (tiny, but phillips #00) screws from the battery compartment.
I actually went further and removed the motherboard to clean the fan. It wasn't too hard thanks to your guide!
Franciozzy - Reply Share
I, too had to remove the battery compartment screws. Other than that, and that I couldn’t get the keyboard cable out, the replacement went flawlessly.
Guy, Just Some - Reply Share
Great stuff, swapped original HD for an SSD. Thank you for this!
Steven - Reply Share
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 50
All Time: 17,115
