Asus Eee PC 1201HAB Hard Drive Replacement
    1. Asus Eee PC 1201HAB Hard Drive Replacement, Keyboard: step 1, image 1 of 2 Asus Eee PC 1201HAB Hard Drive Replacement, Keyboard: step 1, image 2 of 2
      • Use a plastic opening tool and carefully pry the top panel from the base.
      Ask FixBot
    2. Asus Eee PC 1201HAB Hard Drive Replacement: step 2, image 1 of 3 Asus Eee PC 1201HAB Hard Drive Replacement: step 2, image 2 of 3 Asus Eee PC 1201HAB Hard Drive Replacement: step 2, image 3 of 3
      • Slowly lift the keyboard from the base.
      • Disconnect the attached ribbon from under the keyboard.
      Ask FixBot
    3. Asus Eee PC 1201HAB Hard Drive Replacement: step 3, image 1 of 1
      • Remove the keyboard.
      Ask FixBot
    1. Asus Eee PC 1201HAB Hard Drive Replacement, Hard Drive: step 4, image 1 of 2 Asus Eee PC 1201HAB Hard Drive Replacement, Hard Drive: step 4, image 2 of 2
      • Lay the laptop with the back facing up.
      • With a Phillips #0 screwdriver, remove the eight 6mm screws on the back of the laptop.
      Ask FixBot
    2. Asus Eee PC 1201HAB Hard Drive Replacement: step 5, image 1 of 3 Asus Eee PC 1201HAB Hard Drive Replacement: step 5, image 2 of 3 Asus Eee PC 1201HAB Hard Drive Replacement: step 5, image 3 of 3
      • Slide the tabs outward to remove the battery.
      Ask FixBot
    3. Asus Eee PC 1201HAB Hard Drive Replacement: step 6, image 1 of 2 Asus Eee PC 1201HAB Hard Drive Replacement: step 6, image 2 of 2
      • Flip the device so that you are facing the screen.
      • Remove the ten 4mm screws on the silver panel under the keyboard using a Phillips #0 screwdriver.
      Ask FixBot
    4. Asus Eee PC 1201HAB Hard Drive Replacement: step 7, image 1 of 3 Asus Eee PC 1201HAB Hard Drive Replacement: step 7, image 2 of 3 Asus Eee PC 1201HAB Hard Drive Replacement: step 7, image 3 of 3
      • Using a plastic opening tool, remove the top panel of the laptop.
      Ask FixBot
    5. Asus Eee PC 1201HAB Hard Drive Replacement: step 8, image 1 of 2 Asus Eee PC 1201HAB Hard Drive Replacement: step 8, image 2 of 2
      • Using a Phillips #0 screwdriver, remove the four 4mm screws connecting the hard drive.
      Ask FixBot
    6. Asus Eee PC 1201HAB Hard Drive Replacement: step 9, image 1 of 1
      • Remove and replace the hard drive.
      Ask FixBot
Katherine Chan
370 Reputation
2 Guides authored
UC Davis, Team S7-G3, Lore Fall 2018 Member of UC Davis, Team S7-G3, Lore Fall 2018
UCD-LORE-F18S7G3
3 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 95
All Time: 1,949
