Asus Eee PC 1005PEB Wifi Card Replacement
Views: 2.4K
View statistics:
Past 24 Hours:
4
Past 7 Days:
25
Past 30 Days:
90
All Time:
2,367
Comments: 0
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The wifi card is located under the trackpad of the laptop. Before starting the guide, make sure the laptop's charger is not plugged in.
Warning: This guide causes warranty of laptop to be voided.
Tools
    1. Asus Eee PC 1005PEB Wifi Card Replacement, Battery: step 1, image 1 of 1
      • Start by placing the laptop upside-down on a flat surface.
      • Find the two clips on the back portion of the laptop.
      Ask FixBot
    2. Asus Eee PC 1005PEB Wifi Card Replacement: step 2, image 1 of 1
      • Using your finger, push the clip labeled with a "1" on the laptop from the lock position to unlock position.
      • This clip will hold itself, so after you move it to the unlock position you can remove your finger.
      Ask FixBot
    3. Asus Eee PC 1005PEB Wifi Card Replacement: step 3, image 1 of 2 Asus Eee PC 1005PEB Wifi Card Replacement: step 3, image 2 of 2
      • Using your finger, push and hold the pin indicated by a "2" on the laptop from the lock to unlock position.
      • While holding this pin in the unlock position, use your other hand to pull the battery horizontally away from the laptop.
      • When the pins on the battery that reach towards the laptop are away from the laptop, you can release the "2" clip.
      Ask FixBot
    4. Asus Eee PC 1005PEB Wifi Card Replacement: step 4, image 1 of 1
      • Using both hands, pull the battery horizontally away from the laptop.
      Ask FixBot
    1. Asus Eee PC 1005PEB Wifi Card Replacement, Keyboard: step 5, image 1 of 1
      • Face the laptop so the 4 silver "clips" along the middle of the battery cartridge are in front of you.
      Ask FixBot
    2. Asus Eee PC 1005PEB Wifi Card Replacement: step 6, image 1 of 3 Asus Eee PC 1005PEB Wifi Card Replacement: step 6, image 2 of 3 Asus Eee PC 1005PEB Wifi Card Replacement: step 6, image 3 of 3
      • Using the wide opening tool, unhook each clip from its original position by pulling the clip towards you.
      • Repeat for all four of the clips.
      Ask FixBot
    3. Asus Eee PC 1005PEB Wifi Card Replacement: step 7, image 1 of 1
      • Turn the laptop right side up and lift the lid.
      • Insert the flat end of the spudger into the small gap between the top of the keyboard and the plastic of the laptop.
      • Using the spudger as leverage, lift the keyboard up from the rest of the laptop.
      • Run the spudger across the seam until the entire top edge is exposed. The two sides of the keyboard should also pop up in this process.
      Ask FixBot
    4. Asus Eee PC 1005PEB Wifi Card Replacement: step 8, image 1 of 1
      • The keyboard should now lift from the base of the laptop.
      • Do not lift the keyboard up to quickly or too hard, since a ribbon cable is still attached to the keyboard and doing so could break it.
      Ask FixBot
    5. Asus Eee PC 1005PEB Wifi Card Replacement: step 9, image 1 of 3 Asus Eee PC 1005PEB Wifi Card Replacement: step 9, image 2 of 3 Asus Eee PC 1005PEB Wifi Card Replacement: step 9, image 3 of 3
      • Using the pointed end of the spudger tool, disconnect the ribbon cable that extends from the bottom of the keyboard to the computer by pushing on the connections of the cable.
      • Once the ribbon cable is disconnected, the keyboard can be fully removed by lifting it away from the laptop.
      Ask FixBot
    1. Asus Eee PC 1005PEB Wifi Card Replacement, Wifi Card: step 10, image 1 of 2 Asus Eee PC 1005PEB Wifi Card Replacement, Wifi Card: step 10, image 2 of 2
      • Turn laptop upside down.
      • Find and unscrew the 5.5 mm Phillips #1 screw on the ram cover.
      • The screw and ram cover are connected and will not separate.
      Ask FixBot
    2. Asus Eee PC 1005PEB Wifi Card Replacement: step 11, image 1 of 2 Asus Eee PC 1005PEB Wifi Card Replacement: step 11, image 2 of 2
      • Carefully remove the cover by lifting it with your fingers.
      • Make sure that you do not pull the cover too hard because there are plastic pins that hold the cover on.
      Ask FixBot
    3. Asus Eee PC 1005PEB Wifi Card Replacement: step 12, image 1 of 2 Asus Eee PC 1005PEB Wifi Card Replacement: step 12, image 2 of 2
      • Locate and remove the silver 6.65 mm Phillips #1 screw in the bottom right corner of the opening.
      Ask FixBot
    4. Asus Eee PC 1005PEB Wifi Card Replacement: step 13, image 1 of 1
      • Remove the four 6 mm screws with the Phillips #1 screwdriver.
      Ask FixBot
    5. Asus Eee PC 1005PEB Wifi Card Replacement: step 14, image 1 of 3 Asus Eee PC 1005PEB Wifi Card Replacement: step 14, image 2 of 3 Asus Eee PC 1005PEB Wifi Card Replacement: step 14, image 3 of 3
      • Release the 3 black clips by pushing them in with the pointed end of the spludger.
      Ask FixBot
    6. Asus Eee PC 1005PEB Wifi Card Replacement: step 15, image 1 of 1
      • This step will void the warranty
      • Remove the all five 5.5 mm Phillips #1 screws.
      Ask FixBot
    7. Asus Eee PC 1005PEB Wifi Card Replacement: step 16, image 1 of 1
      • Remove the ribbon cable that is connected to the circuit board with the pointed end of the spudger.
      Ask FixBot
    8. Asus Eee PC 1005PEB Wifi Card Replacement: step 17, image 1 of 3 Asus Eee PC 1005PEB Wifi Card Replacement: step 17, image 2 of 3 Asus Eee PC 1005PEB Wifi Card Replacement: step 17, image 3 of 3
      • Pry up the plastic frame at the top corners.
      • Use the wide end of spudger and slide it between the bottom case and the plastic red to release it.
      • The red plastic frame and the silver piece of metal are connected and will come off together.
      Ask FixBot
    9. Asus Eee PC 1005PEB Wifi Card Replacement: step 18, image 1 of 2 Asus Eee PC 1005PEB Wifi Card Replacement: step 18, image 2 of 2
      • Fold back the ribbon cable away from you.
      • Remove the 3.6 mm Phillip #1 screw.
      Ask FixBot
    10. Asus Eee PC 1005PEB Wifi Card Replacement: step 19, image 1 of 1
      • Fold the ribbon cable the opposite way and lift up the wifi card.
      Ask FixBot
    11. Asus Eee PC 1005PEB Wifi Card Replacement: step 20, image 1 of 2 Asus Eee PC 1005PEB Wifi Card Replacement: step 20, image 2 of 2
      • Remove the Wi-Fi card by pulling the card away from where it was plugged in.
      • Don't pull the wifi card out too fast because the antenna is still attached and doing so could damage the antenna or connector.
      Ask FixBot
    12. Asus Eee PC 1005PEB Wifi Card Replacement: step 21, image 1 of 2 Asus Eee PC 1005PEB Wifi Card Replacement: step 21, image 2 of 2
      • Pull the antenna away from the wifi card to remove it.
      Ask FixBot
4 other people completed this guide.
Aaron Arenas
751 Reputation
5 Guides authored
Cal Poly, Team 13-32, Maness Spring 2014 Member of Cal Poly, Team 13-32, Maness Spring 2014
CPSU-MANESS-S14S13G32
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 90
All Time: 2,367
