Introduction
Go to step 1 ↓The keyboard on the top of the laptop connected the motherboard. Before starting the guide, make sure the laptop's charger is not plugged in.
Tools
Spudger4.9
Start by placing the laptop upside-down on a flat surface.
Find the two clips on the back portion of the laptop.
Face the laptop so the 4 silver "clips" along the middle of the battery cartridge are in front of you.
Turn the laptop right side up and lift the lid.
Insert the flat end of the spudger into the small gap between the top of the keyboard and the plastic of the laptop.
Using the spudger as leverage, lift the keyboard up from the rest of the laptop.
Run the spudger across the seam until the entire top edge is exposed. The two sides of the keyboard should also pop up in this process.
4 other people completed this guide.
