Asus Eee PC 1005HA Screen Replacement
Views: 23K
View statistics:
Past 24 Hours:
5
Past 7 Days:
23
Past 30 Days:
117
All Time:
22,669
Comments: 0
Go to guide comments
Completed: 13
13 people have marked this guide "completed." Will you be next?
Favorites: 18
18 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Use this guide to replace the screen of the Replace the screen on your Asus Eee PC 1005HA laptop.
Parts
Tools
    1. Asus Eee PC 1005HA Screen Replacement, Battery: step 1, image 1 of 1
      • Lay the laptop upside down.
      • Locate the two battery lock tabs.
      Ask FixBot
    2. Asus Eee PC 1005HA Screen Replacement: step 2, image 1 of 3 Asus Eee PC 1005HA Screen Replacement: step 2, image 2 of 3 Asus Eee PC 1005HA Screen Replacement: step 2, image 3 of 3
      • Slide the tabs outward to unlock the battery.
      • The left tab will remain unlocked, while the right tab must be held.
      • Holding the right tab open, slide the battery out of the laptop.
      Ask FixBot
    1. Asus Eee PC 1005HA Screen Replacement, Screen: step 3, image 1 of 3 Asus Eee PC 1005HA Screen Replacement, Screen: step 3, image 2 of 3 Asus Eee PC 1005HA Screen Replacement, Screen: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • Using tweezers, remove the six screw covers on the screen bezel.
      • Remove the six 4.6 mm screws from the bezel.
      Ask FixBot
    2. Asus Eee PC 1005HA Screen Replacement: step 4, image 1 of 1
      • Use a plastic opening tool to disengage the plastic clips that secure the screen bezel to the display.
      • Carefully remove the bezel from the display.
      Ask FixBot
    3. Asus Eee PC 1005HA Screen Replacement: step 5, image 1 of 3 Asus Eee PC 1005HA Screen Replacement: step 5, image 2 of 3 Asus Eee PC 1005HA Screen Replacement: step 5, image 3 of 3
      • Remove the four 3.6 mm screws securing the screen.
      • Slowly lift the screen up from the rest of the laptop.
      • The screen is still attached to the laptop by a set of cables. Be careful not to damage them while removing the screen.
      Ask FixBot
    4. Asus Eee PC 1005HA Screen Replacement: step 6, image 1 of 2 Asus Eee PC 1005HA Screen Replacement: step 6, image 2 of 2
      • Remove the plastic tape securing the display cables to the back of the screen.
      • Slide the display cable connector out its socket on the back of the screen.
      Ask FixBot
    5. Asus Eee PC 1005HA Screen Replacement: step 7, image 1 of 2 Asus Eee PC 1005HA Screen Replacement: step 7, image 2 of 2
      • Remove the four 3.1 mm housing screws on the sides of the display housing frame
      • Remove the housing frame.
      Ask FixBot
13 other people completed this guide.
Mitchell Cesare
811 Reputation
4 Guides authored
Cal Poly, Team 11-22, Maness Winter 2012 Member of Cal Poly, Team 11-22, Maness Winter 2012
CPSU-MANESS-W12S11G22
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 23
Past 30 Days: 117
All Time: 22,669
