Asus Eee PC 1005HA Keyboard Replacement
    1. Asus Eee PC 1005HA Keyboard Replacement, Battery: step 1, image 1 of 1
      • Lay the laptop upside down.
      • Locate the two battery lock tabs.
      Ask FixBot
    2. Asus Eee PC 1005HA Keyboard Replacement: step 2, image 1 of 3 Asus Eee PC 1005HA Keyboard Replacement: step 2, image 2 of 3 Asus Eee PC 1005HA Keyboard Replacement: step 2, image 3 of 3
      • Slide the tabs outward to unlock the battery.
      • The left tab will remain unlocked, while the right tab must be held.
      • Holding the right tab open, slide the battery out of the laptop.
      Ask FixBot
    1. Asus Eee PC 1005HA Keyboard Replacement, Keyboard: step 3, image 1 of 2 Asus Eee PC 1005HA Keyboard Replacement, Keyboard: step 3, image 2 of 2
      • Use a plastic opening tool to pull up the four metal latches in the battery cavity that is located on the bottom of the laptop.
      • Do not apply too much pressure. The latches can not be removed and will bend if forced.
      Ask FixBot
    2. Asus Eee PC 1005HA Keyboard Replacement: step 4, image 1 of 3 Asus Eee PC 1005HA Keyboard Replacement: step 4, image 2 of 3 Asus Eee PC 1005HA Keyboard Replacement: step 4, image 3 of 3
      • Flip the laptop over, and open the display.
      • Use a plastic opening tool to lift the edge of the keyboard that is nearest to the screen.
      • Gently lift the keyboard and slide it toward the screen.
      • Do not remove the keyboard completely. This can damage the ribbon cable connecting the underside of the keyboard to the laptop.
      Ask FixBot
    3. Asus Eee PC 1005HA Keyboard Replacement: step 5, image 1 of 1
      • Use a spudger tool to release the tabs on the ribbon cable ZIF connector that is attached to the underside of the keyboard.
      • Depending on the model, the tabs on this ZIF connector will either flip up toward the display or push out toward the display.
      • Once the ZIF connector tabs have been released, remove the keyboard.
      Ask FixBot
12 other people completed this guide.
Chris Beichler
600 Reputation
2 Guides authored
Cal Poly, Team 11-22, Maness Winter 2012 Member of Cal Poly, Team 11-22, Maness Winter 2012
CPSU-MANESS-W12S11G22
3 Members
72 Guides authored
1 Guide Comment
after i upgrade my bios keyboard stop working . but external keyboard working fine.. plz help
anytimerabin - Reply Share
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 31
All Time: 24,199
