Asus Chromebook Flip C436F Battery Replacement
    1. Asus Chromebook Flip C436F Battery Replacement, Asus C436F Chromebook Battery: step 1, image 1 of 1
      • Flip your Chromebook over so the bottom case is facing up.
      • Use a Torx T5 screwdriver to remove eleven 3 mm screws from the bottom of your device.
      • There are three screws under the rubber strip near the hinge.
      Ask FixBot
    2. Asus Chromebook Flip C436F Battery Replacement: step 2, image 1 of 1
      • Insert the end of an opening tool into the seam between the bottom and top case to release the clips holding them together.
      • Remove the back panel of your Chromebook.
      Ask FixBot
    3. Asus Chromebook Flip C436F Battery Replacement: step 3, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the four M2 x 3 mm screws holding the battery to the chassis.
      Ask FixBot
    4. Asus Chromebook Flip C436F Battery Replacement: step 4, image 1 of 2 Asus Chromebook Flip C436F Battery Replacement: step 4, image 2 of 2
      • Slide the metal lock that connects the battery to the motherboard backward (to the right). Then, lift the white connector straight out of the socket on the motherboard.
      Ask FixBot
    5. Asus Chromebook Flip C436F Battery Replacement: step 5, image 1 of 1
      • Remove the battery from your Chromebook.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. For optimal performance, calibrate your newly installed battery after completing this guide.
RusselSprout
121 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 55
All Time: 841
