Asus Chromebook Flip C302CA Display Replacement
    1. Asus Chromebook Flip C302CA Display Replacement, Back Panel: step 1, image 1 of 1
      • Turn the laptop over so the bottom is facing you.
      Ask FixBot
    2. Asus Chromebook Flip C302CA Display Replacement: step 2, image 1 of 3 Asus Chromebook Flip C302CA Display Replacement: step 2, image 2 of 3 Asus Chromebook Flip C302CA Display Replacement: step 2, image 3 of 3
      • Remove two rubber caps on the top.
      • Remove the two 1 mm screws using the Phillips #00 screwdriver.
      Ask FixBot
    3. Asus Chromebook Flip C302CA Display Replacement: step 3, image 1 of 3 Asus Chromebook Flip C302CA Display Replacement: step 3, image 2 of 3 Asus Chromebook Flip C302CA Display Replacement: step 3, image 3 of 3
      • Remove the ten 2 mm screws from the back panel using a T5 Torx screwdriver.
      • Carefully remove the back panel using an opening pick.
      Ask FixBot
    4. Asus Chromebook Flip C302CA Display Replacement: step 4, image 1 of 2 Asus Chromebook Flip C302CA Display Replacement: step 4, image 2 of 2
      • Remove the back panel from the laptop.
      Ask FixBot
    1. Asus Chromebook Flip C302CA Display Replacement, Display: step 5, image 1 of 1
      • Remove the black display ports from the motherboard.
      Ask FixBot
    2. Asus Chromebook Flip C302CA Display Replacement: step 6, image 1 of 1
      • Remove the six 2.54 mm Phillips screws from the left and right screen hinge brackets.
      Ask FixBot
    3. Asus Chromebook Flip C302CA Display Replacement: step 7, image 1 of 1
      • Remove the display unit.
      Ask FixBot
    4. Asus Chromebook Flip C302CA Display Replacement: step 8, image 1 of 1
      • Use heat gun to loosen up adhesive on rubber covers for screw.
      Ask FixBot
    5. Asus Chromebook Flip C302CA Display Replacement: step 9, image 1 of 1
      • Remove rubber covers.
      Ask FixBot
    6. Asus Chromebook Flip C302CA Display Replacement: step 10, image 1 of 1
      • Remove the two 2.5 mm screws.
      Ask FixBot
    7. Asus Chromebook Flip C302CA Display Replacement: step 11, image 1 of 1
      • Use prying tool to separate panel from monitor.
      Ask FixBot
    8. Asus Chromebook Flip C302CA Display Replacement: step 12, image 1 of 1
      • Remove this connection by pulling to separate it from the monitor.
      Ask FixBot
    9. Asus Chromebook Flip C302CA Display Replacement: step 13, image 1 of 1
      • Remove connection point and the entire camera assembly including wires.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 31
All Time: 675
