Asus Chromebook Flip C302CA Back Panel Replacement
    1. Asus Chromebook Flip C302CA Back Panel Replacement, Back Panel: step 1, image 1 of 1
      • Turn the laptop over so the bottom is facing you.
      Ask FixBot
    2. Asus Chromebook Flip C302CA Back Panel Replacement: step 2, image 1 of 3 Asus Chromebook Flip C302CA Back Panel Replacement: step 2, image 2 of 3 Asus Chromebook Flip C302CA Back Panel Replacement: step 2, image 3 of 3
      • Remove two rubber caps on the top.
      • Remove the two 1 mm screws using the Phillips #00 screwdriver.
      Ask FixBot
    3. Asus Chromebook Flip C302CA Back Panel Replacement: step 3, image 1 of 3 Asus Chromebook Flip C302CA Back Panel Replacement: step 3, image 2 of 3 Asus Chromebook Flip C302CA Back Panel Replacement: step 3, image 3 of 3
      • Remove the ten 2 mm screws from the back panel using a T5 Torx screwdriver.
      • Carefully remove the back panel using an opening pick.
      Ask FixBot
    4. Asus Chromebook Flip C302CA Back Panel Replacement: step 4, image 1 of 2 Asus Chromebook Flip C302CA Back Panel Replacement: step 4, image 2 of 2
      • Remove the back panel from the laptop.
      Ask FixBot
Kristen Gismondi
108,479 Reputation
271 Guides authored
iFixit Member of iFixit
Staff
123 Members
76,498 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 23
All Time: 390
