Asus Chromebook Flip C100 Lower Case Replacement
    1. Asus Chromebook Flip C100 Lower Case Replacement, Lower Case: step 1, image 1 of 1
      • Unscrew the eight bottom cover screws (one of them is under the hand) using a screwdriver with a J1000 tip.
      • Unscrew the middle screw towards the top of the device using a screwdriver with a T5 tip.
      Ask FixBot
    2. Asus Chromebook Flip C100 Lower Case Replacement: step 2, image 1 of 1
      • Use the plastic opening tool to remove the four bottom rubber feet.
      Ask FixBot
    3. Asus Chromebook Flip C100 Lower Case Replacement: step 3, image 1 of 1
      • Unscrew the four screws under the feet using a screwdriver with a J100 tip.
      Ask FixBot
    4. Asus Chromebook Flip C100 Lower Case Replacement: step 4, image 1 of 1
      • Use the plastic opening tool to pry up the palm rest assembly.
      Ask FixBot
    5. Asus Chromebook Flip C100 Lower Case Replacement: step 5, image 1 of 1
      Tool used on this step:
      Buy
      • Disconnect the two cables from the motherboard with tweezers
      Ask FixBot
11 other people completed this guide.
1 Guide Comment
great guide, though i found the nine screws on the outside required a t5 tip, while the 5 under the feet looked like they were either j100 or j1000, but a philips head worked.
Matthew Sylvester - Reply Share
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 33
All Time: 5,681
