Asus Chromebook CX1500CKA-AS84F Trackpad Replacement
    1. Asus Chromebook CX1500CKA-AS84F Trackpad Replacement, Back Cover: step 1, image 1 of 2 Asus Chromebook CX1500CKA-AS84F Trackpad Replacement, Back Cover: step 1, image 2 of 2
      • Remove the ten 7 mm JIS #00 screws from the bottom edge of the Chromebook.
      • Remove the one 7 mm JIS #00 screw in the middle, above the tag.
      Ask FixBot
    2. Asus Chromebook CX1500CKA-AS84F Trackpad Replacement: step 2, image 1 of 3 Asus Chromebook CX1500CKA-AS84F Trackpad Replacement: step 2, image 2 of 3 Asus Chromebook CX1500CKA-AS84F Trackpad Replacement: step 2, image 3 of 3
      • Use a plastic opening tool to carefully lift the bottom cover and take it off the laptop.
      • Avoid using metal tools to pry open the case, as this can damage the housing.
      Ask FixBot
    1. Asus Chromebook CX1500CKA-AS84F Trackpad Replacement, Battery: step 3, image 1 of 3 Asus Chromebook CX1500CKA-AS84F Trackpad Replacement, Battery: step 3, image 2 of 3 Asus Chromebook CX1500CKA-AS84F Trackpad Replacement, Battery: step 3, image 3 of 3
      • To disconnect the cable, use a spudger or your fingernail to lift the locking tab.
      • Use your hand to carefully unplug the battery cable from the motherboard.
      Ask FixBot
    2. Asus Chromebook CX1500CKA-AS84F Trackpad Replacement: step 4, image 1 of 1
      • Remove five 2 mm JIS #00 screws from the battery.
      Ask FixBot
    3. Asus Chromebook CX1500CKA-AS84F Trackpad Replacement: step 5, image 1 of 2 Asus Chromebook CX1500CKA-AS84F Trackpad Replacement: step 5, image 2 of 2
      • Remove the battery from the laptop.
      Ask FixBot
    1. Asus Chromebook CX1500CKA-AS84F Trackpad Replacement, Trackpad: step 6, image 1 of 2 Asus Chromebook CX1500CKA-AS84F Trackpad Replacement, Trackpad: step 6, image 2 of 2
      • Carefully pull on the trackpad cable to disconnect it from the motherboard.
      Ask FixBot
    2. Asus Chromebook CX1500CKA-AS84F Trackpad Replacement: step 7, image 1 of 2 Asus Chromebook CX1500CKA-AS84F Trackpad Replacement: step 7, image 2 of 2
      • Gently remove the tape from the frame.
      Ask FixBot
    3. Asus Chromebook CX1500CKA-AS84F Trackpad Replacement: step 8, image 1 of 2 Asus Chromebook CX1500CKA-AS84F Trackpad Replacement: step 8, image 2 of 2
      • Remove the three 2 mm screws using a Phillips #1 screwdriver.
      Ask FixBot
    4. Asus Chromebook CX1500CKA-AS84F Trackpad Replacement: step 9, image 1 of 2 Asus Chromebook CX1500CKA-AS84F Trackpad Replacement: step 9, image 2 of 2
      • Lift off the trackpad to remove it.
      Ask FixBot
Ron Balladares
243 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 22
All Time: 108
