Asus Chromebook C300SA-DS02 Trackpad Replacement
    1. Asus Chromebook C300SA-DS02 Trackpad Replacement, Keyboard: step 1, image 1 of 2 Asus Chromebook C300SA-DS02 Trackpad Replacement, Keyboard: step 1, image 2 of 2
      • Power the laptop off and make sure the charger is unplugged before starting.
      • Remove the eight 8.0mm Phillips #0 screws on the bottom of the laptop.
      • Remove the three 6.0mm Phillips #0 screws.
      Ask FixBot
    2. Asus Chromebook C300SA-DS02 Trackpad Replacement: step 2, image 1 of 3 Asus Chromebook C300SA-DS02 Trackpad Replacement: step 2, image 2 of 3 Asus Chromebook C300SA-DS02 Trackpad Replacement: step 2, image 3 of 3
      • Open the laptop.
      • Using an iFixit opening tool, pry along the edges of the keyboard.
      • Lift the keyboard and slide it gently towards you.
      • Do not completely remove the keyboard. It is still connected to the back panel by a pair of ribbon cables.
      Ask FixBot
    3. Asus Chromebook C300SA-DS02 Trackpad Replacement: step 3, image 1 of 3 Asus Chromebook C300SA-DS02 Trackpad Replacement: step 3, image 2 of 3 Asus Chromebook C300SA-DS02 Trackpad Replacement: step 3, image 3 of 3
      • Disconnect the two ZIF connectors by prying up the locking bar with a spudger and removing the ribbon cable.
      Ask FixBot
    4. Asus Chromebook C300SA-DS02 Trackpad Replacement: step 4, image 1 of 1
      • Remove the keyboard from the laptop.
      Ask FixBot
    1. Asus Chromebook C300SA-DS02 Trackpad Replacement, Trackpad: step 5, image 1 of 2 Asus Chromebook C300SA-DS02 Trackpad Replacement, Trackpad: step 5, image 2 of 2
      • Flip over the keyboard assembly to reveal the trackpad beneath.
      Ask FixBot
    2. Asus Chromebook C300SA-DS02 Trackpad Replacement: step 6, image 1 of 2 Asus Chromebook C300SA-DS02 Trackpad Replacement: step 6, image 2 of 2
      • Peel up the two pieces of foil tape holding down the trackpad.
      Ask FixBot
    3. Asus Chromebook C300SA-DS02 Trackpad Replacement: step 7, image 1 of 3 Asus Chromebook C300SA-DS02 Trackpad Replacement: step 7, image 2 of 3 Asus Chromebook C300SA-DS02 Trackpad Replacement: step 7, image 3 of 3
      • Use a spudger to release the locking bar of the ZIF connector near the center of the trackpad.
      • Slide the cable ribbon from the connector.
      Ask FixBot
    4. Asus Chromebook C300SA-DS02 Trackpad Replacement: step 8, image 1 of 1
      • Peel back the ribbon cable, which is adhered to the trackpad.
      Ask FixBot
    5. Asus Chromebook C300SA-DS02 Trackpad Replacement: step 9, image 1 of 3 Asus Chromebook C300SA-DS02 Trackpad Replacement: step 9, image 2 of 3 Asus Chromebook C300SA-DS02 Trackpad Replacement: step 9, image 3 of 3
      • Remove the four 2.5mm Phillips #0 screws along the top edge of the trackpad.
      Ask FixBot
    6. Asus Chromebook C300SA-DS02 Trackpad Replacement: step 10, image 1 of 2 Asus Chromebook C300SA-DS02 Trackpad Replacement: step 10, image 2 of 2
      • Pry the trackpad from the top edge with a finger or spudger.
      • Lift the trackpad up and away from the keyboard assembly.
      Ask FixBot
Austin Blakely
23,173 Reputation
53 Guides authored
iFixit Member of iFixit
Staff
123 Members
79,118 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 30
All Time: 554
