Asus Chromebook C300SA-DS02 LED Screen Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
33
Past 30 Days:
88
All Time:
1,249
Comments: 6
5 comments on steps, 1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will walk you through the step by step process of removing the LED screen from the laptop. Screen removal is a multistep process that will require you to keep track of the parts taken out of the laptop. Each screw is accounted for in the steps they are removed.
Tools
    1. Asus Chromebook C300SA-DS02 LED Screen Replacement, Keyboard: step 1, image 1 of 2 Asus Chromebook C300SA-DS02 LED Screen Replacement, Keyboard: step 1, image 2 of 2
      • Power the laptop off and make sure the charger is unplugged before starting.
      • Remove the eight 8.0mm Phillips #0 screws on the bottom of the laptop.
      • Remove the three 6.0mm Phillips #0 screws.
      Ask FixBot
    2. Asus Chromebook C300SA-DS02 LED Screen Replacement: step 2, image 1 of 3 Asus Chromebook C300SA-DS02 LED Screen Replacement: step 2, image 2 of 3 Asus Chromebook C300SA-DS02 LED Screen Replacement: step 2, image 3 of 3
      • Open the laptop.
      • Using an iFixit opening tool, pry along the edges of the keyboard.
      • Lift the keyboard and slide it gently towards you.
      • Do not completely remove the keyboard. It is still connected to the back panel by a pair of ribbon cables.
      Ask FixBot
    3. Asus Chromebook C300SA-DS02 LED Screen Replacement: step 3, image 1 of 3 Asus Chromebook C300SA-DS02 LED Screen Replacement: step 3, image 2 of 3 Asus Chromebook C300SA-DS02 LED Screen Replacement: step 3, image 3 of 3
      • Disconnect the two ZIF connectors by prying up the locking bar with a spudger and removing the ribbon cable.
      Ask FixBot
    4. Asus Chromebook C300SA-DS02 LED Screen Replacement: step 4, image 1 of 1
      • Remove the keyboard from the laptop.
      Ask FixBot
    1. Asus Chromebook C300SA-DS02 LED Screen Replacement, Battery: step 5, image 1 of 2 Asus Chromebook C300SA-DS02 LED Screen Replacement, Battery: step 5, image 2 of 2
      • Remove the six 5.6mm Phillips #0 screws around the battery.
      Ask FixBot
    2. Asus Chromebook C300SA-DS02 LED Screen Replacement: step 6, image 1 of 2 Asus Chromebook C300SA-DS02 LED Screen Replacement: step 6, image 2 of 2
      • Using your thumb and index finger, pinch the multi-color cable and disconnect it from the motherboard.
      Ask FixBot
    3. Asus Chromebook C300SA-DS02 LED Screen Replacement: step 7, image 1 of 1
      • Lift the battery out of the laptop.
      Ask FixBot
    1. Asus Chromebook C300SA-DS02 LED Screen Replacement, LED Screen: step 8, image 1 of 2 Asus Chromebook C300SA-DS02 LED Screen Replacement, LED Screen: step 8, image 2 of 2
      • Unplug the black and white cable from the motherboard.
      • These two wires connect to the antenna within the display assembly. The white cable is longer and connects to the bottom import.
      Ask FixBot
    2. Asus Chromebook C300SA-DS02 LED Screen Replacement: step 9, image 1 of 1
      • Peel back the tape covering the plug.
      • Slide the cable towards the screen and out of the input.
      Ask FixBot
    3. Asus Chromebook C300SA-DS02 LED Screen Replacement: step 10, image 1 of 1
      • Unscrew the 6 screws (5 millimeter) on the top right and left.
      Ask FixBot
    4. Asus Chromebook C300SA-DS02 LED Screen Replacement: step 11, image 1 of 1
      • Gently lift the screen up and away from the laptop.
      Ask FixBot
    5. Asus Chromebook C300SA-DS02 LED Screen Replacement: step 12, image 1 of 1
      • Pry off the face panel on the screen using the blue prying tool.
      Ask FixBot
    6. Asus Chromebook C300SA-DS02 LED Screen Replacement: step 13, image 1 of 1
      • Remove the four 2mm Phillips #0 screws from the four corners of the screen.
      Ask FixBot
    7. Asus Chromebook C300SA-DS02 LED Screen Replacement: step 14, image 1 of 2 Asus Chromebook C300SA-DS02 LED Screen Replacement: step 14, image 2 of 2
      • Gently lift screen
      • Peel back the adhesive covering the cable.
      • Remove the cable to free the screen.
      Ask FixBot
2 other people completed this guide.
Celina Monteiro
233 Reputation
2 Guides authored
1 Guide Comment
I used this honestly I broke the screen and some of the wires in the screen are severed. Now I know for sure where the wires go and how to deconstruct it. Thank you so much!
Glorybringers Child - Reply Share
Past 24 Hours: 4
Past 7 Days: 33
Past 30 Days: 88
All Time: 1,249
