Asus Chromebook C300SA-DS02 Display Assembly Replacement
    1. Asus Chromebook C300SA-DS02 Display Assembly Replacement, Keyboard: step 1, image 1 of 2 Asus Chromebook C300SA-DS02 Display Assembly Replacement, Keyboard: step 1, image 2 of 2
      • Power the laptop off and make sure the charger is unplugged before starting.
      • Remove the eight 8.0mm Phillips #0 screws on the bottom of the laptop.
      • Remove the three 6.0mm Phillips #0 screws.
      Ask FixBot
    2. Asus Chromebook C300SA-DS02 Display Assembly Replacement: step 2, image 1 of 3 Asus Chromebook C300SA-DS02 Display Assembly Replacement: step 2, image 2 of 3 Asus Chromebook C300SA-DS02 Display Assembly Replacement: step 2, image 3 of 3
      • Open the laptop.
      • Using an iFixit opening tool, pry along the edges of the keyboard.
      • Lift the keyboard and slide it gently towards you.
      • Do not completely remove the keyboard. It is still connected to the back panel by a pair of ribbon cables.
      Ask FixBot
    3. Asus Chromebook C300SA-DS02 Display Assembly Replacement: step 3, image 1 of 3 Asus Chromebook C300SA-DS02 Display Assembly Replacement: step 3, image 2 of 3 Asus Chromebook C300SA-DS02 Display Assembly Replacement: step 3, image 3 of 3
      • Disconnect the two ZIF connectors by prying up the locking bar with a spudger and removing the ribbon cable.
      Ask FixBot
    4. Asus Chromebook C300SA-DS02 Display Assembly Replacement: step 4, image 1 of 1
      • Remove the keyboard from the laptop.
      Ask FixBot
    1. Asus Chromebook C300SA-DS02 Display Assembly Replacement, Battery: step 5, image 1 of 2 Asus Chromebook C300SA-DS02 Display Assembly Replacement, Battery: step 5, image 2 of 2
      • Remove the six 5.6mm Phillips #0 screws around the battery.
      Ask FixBot
    2. Asus Chromebook C300SA-DS02 Display Assembly Replacement: step 6, image 1 of 2 Asus Chromebook C300SA-DS02 Display Assembly Replacement: step 6, image 2 of 2
      • Using your thumb and index finger, pinch the multi-color cable and disconnect it from the motherboard.
      Ask FixBot
    3. Asus Chromebook C300SA-DS02 Display Assembly Replacement: step 7, image 1 of 1
      • Lift the battery out of the laptop.
      Ask FixBot
    1. Asus Chromebook C300SA-DS02 Display Assembly Replacement, Display Assembly: step 8, image 1 of 2 Asus Chromebook C300SA-DS02 Display Assembly Replacement, Display Assembly: step 8, image 2 of 2
      • Unplug the black and white cable from the motherboard.
      • These two wires connect to the antenna within the display assembly. The white cable is longer and connects to the bottom import.
      Ask FixBot
    2. Asus Chromebook C300SA-DS02 Display Assembly Replacement: step 9, image 1 of 1
      • Peel back the tape covering the display cable.
      • Ease the cable towards the screen and out from the connector.
      Ask FixBot
    3. Asus Chromebook C300SA-DS02 Display Assembly Replacement: step 10, image 1 of 1
      • Use a Phillips #0 driver to remove the six 5mm screws on the top right and left display hinges.
      Ask FixBot
    4. Asus Chromebook C300SA-DS02 Display Assembly Replacement: step 11, image 1 of 1
      • Gently lift the display assembly up and away from the laptop.
      Ask FixBot
Celina Monteiro
233 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 27
All Time: 504
